Spring question!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyfumes, Jan 8, 2003.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I was wondering if anybody has ran an adda leaf and a zero rate, or do they have 2" adda leafs for Tuff Country EZ rides????There was some slight mis-gonculation on my attempt to get rid of the saggy butt Blazer look...
  2. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    I have both(flip-kit/zero rate waiting), and I could tell you as soon as I can find some U bolts for the zero rates. Right now I have 'Summits' short 2.5" add a leaf(w/ a block), and it gave about 1-1.5". I got the mini and mid size #EXP-13120 since the long is such a hassle and the short (I've had) add-a-leaf for 1/2,3/4, and 1 ton is pretty thick and takes away from the ride. I've had this leaf for a year and a half and the ride is worth it, and it's only $26.95 and took me 45min to install. The more lift, the stiffer they ride...
  3. chevyfumes
    Feb 24, 2000
    38,584
    266
    Anybody?????
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I flipped my old overload over and bolted it onto the bottom of the spring pack, ride stayed the same...if you have one lying around it should do the trick, got rid of my saggy butt...if you tow a lot you could even put it in right side up for a firmer spring rate
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    My brother just re lifted the 79 Jimmy I had. He went with the 6" trailmaster kit. it came with rear blocks an add a leaf. He ditched the blocks and did a drop through shackle flip. afterwards he still ended up doing a 2" block with the add a leaf to make up for the sagging ass and fresh 6" fronts.
    Now he is looking at doing a 4" block and getting rid of the add a leafs since it rides like crap.
    i take it you aren't running a flip?
    -Jeremy
    The one who F'd up on the tire carrier deal,LOL
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
    I dig your sig..........LOL
  7. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I thought you would like that.
  8. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I had an add-a-leaf at one time on an earlier K5...........the ride sucked. What is your setup now? Stock rear springs, or what? /forums/images/graemlins/tongue.gif
  9. chevyfumes
    Feb 24, 2000
    38,584
    266
    Tuff country EZ rides, 3" in back and 2" in front with HD ORD shackles so 2 1/2" and I wanted to go with a 2 1/2" ORD shackleflip and I have a pair of 0 rates for up front but that means it would be 5 1/2 in back and 3 1/2 in front, even if I could just get the front up to 4 I'd be happy.... /forums/images/graemlins/deal.gif
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Look into running the Hill Off Road front shackles they are a full 1" lift.
    then flip the rear add a leaf and it should be about right.
  11. chevyfumes
    Feb 24, 2000
    38,584
    266
    /forums/images/graemlins/thumb.gifgotta link???
  12. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Here you go:
    Hill lift shackles
    You can read the review here at ColoradoK5 HERE.
    I've got a set sitting in my toolbox just waiting to get installed. From what I understand, you will need to put in about a 4 degree wedge to correct pinion angle since they only lift one end of your spring.
  13. chevyfumes
    Feb 24, 2000
    38,584
    266
    Cool thanks, I don't know how I ever missed that on Steves write up.... /forums/images/graemlins/thumb.gifThanks guy's....
