spring questions
Discussion in 'The Garage' started by patches85, Apr 24, 2005.
  1. patches85
    patches85 Registered Member
    Jan 17, 2005
    51
    Lewistown PA. the armpit of the state!
    Hey guys can anyone tell me if the leaf springs from a 74 will work on my 85? Is this a direct replacement or is there modifications? :hack: :weld: :grind: :1zhelp:
  2. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    need more in fo? front /back / 1/2 ton 3/4 ton 1 ton what is both specs ?
  3. patches85
    Jan 17, 2005
    51
    12 bolt rear dana 44 up front> they are off of a 74 I am hoping to use on my 85. They are aftermarket lift springs
  4. sweetk30
    Nov 1, 2004
    25,538
    538
    axles dont matter for this. and you didnt read my question correctly but hear is the info to the best of my limits.
    front springs are all the same 1/2 -1 ton . and there is 52 rear and 56 rear in the springs eye to eye . 1/2 ton is 52 most 3/4 ton 52 and some 3/4 ton 56 and 1 ton all 56.
  5. patches85
    Jan 17, 2005
    51
    I scored a 74 for 50 bucks. It has a suspension lift and also a body lift. I believe these trucks have a 44 in front and a 12 bolt in the rear. I want to use them in my 85. The reason I bought it was for the full top. I want to put it on my 85. Any help? Pics suggestions any thing. I don't know what the doors are supposed to look like or the bedsides?
  6. sweetk30
    Nov 1, 2004
    25,538
    538
    those are the axles . dana 44 is the front . 12 bolt is the rear. and if k5 blazer springs are 52 in the rear . will work no problem. but axle swap could be 1 or 2 things in the rear. such as ujoint size . but vary easy swaps.
  7. patches85
    Jan 17, 2005
    51
    What about the roof? doors need cut? bedsides need support ? any help
  8. sweetk30
    Nov 1, 2004
    25,538
    538
    this is a whole other thread that need starting.
  9. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I had a 1 ton a few yrs ago that had 52" rear springs.
