spring questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coolhandluke, Feb 13, 2002.
  1. coolhandluke
    coolhandluke 1/2 ton status
    Oct 23, 2001
    116
    Dallas Texas
    2 spring questions
    ok, I have a problem on my blazer, the guy that had it before me put 33" on there, with no lift. The problem is made worse by the fact that the front springs appear to me to be shot (translation, LOTS of rubbing, even when just driving down the street)
    I bought a 2.5 inch add a leaf lift, but couldn't get it on. should the front springs arch up (like a smile?) mine aren't even straight across, but actually arch DOWN, so i couldn't get the add a leaf on.
    if these springs are shot, would it be cheaper to just buy a lift with new springs, or could I get some out of a junkyard? if I can, do trucks and suburbans have the same front springs?
    83 k5 originally diesel, now 350, 700-R4 12 bolt rear, 33x12.50 BFG Trails (yuck), desperately seeking a lift
    sometimes nothing is a real cool hand
  2. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i have a set of stock front springs if ur want them
    id sell em cheap
    email me at Confederate9@aol.com
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  3. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    I've been spring shopping lately and you can pickup a set of TuffCountry EZ rides (2.5 or 4") for $190 plus shipping. The 2.5" lift would be easiest for you, wouldn't need a raised arm, but you'd need to lift the back.
    Another option would be ORD's zero rate add-a-leaf kit. Get an inch of lift, may need longer u-bolts, but you could do front and back. They run about $30 a set, you'll need 2 sets if you want to do front and back.
    Have fun,
    John<P ID="edit"><FONT class="small">Edited by TwoCrows on 02/13/02 07:47 AM.</FONT></P>
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    why cant you get the add a leafs in? the springs shouldnt be inverted when you take the weight of the k5 off it.
  5. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Are you using C-clamps to get the add a leafs in? I just put some in the back of my Sub in Jan. I used the C-clamps to get the springs to conform to each other.
    I wouldn't go with junk yard springs, they'll sag just as much as your current springs. Go on the wanted and parts for sale board and post springs wanted and look for springs. Somebody local has to have some old lift springs laying aroud. I have a set of 2.5" springs in my garage that you can come pic up if you weren't in Texas.
    Front springs from a K5 fit Subs and Pickups.
    Good luck.
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
    It's a wheelbase thing, you wouldn't understand.
  6. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Since no one answered this question yet,
    NO, the stock front spring does not arch up. (That's what lift springs do obviously :)
    They are flat when no weight is on em, but with weight on, they'll arch down.
    Yours could be worn out though. Fitting 33"s and no lift, usually will cause some rubbing.
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  7. dyeager535
    26,980
    What kind of wheels are you running? Not that different backspacing is going to cause problems, but there are a LOT of people running either 33x12.5's or 33x10.5's (myself included) that don't have problems with rubbing, at least on the street. My 10.5's don't rub off-road either.
    www.dorianyeager.com/index2.html
    Why insist on counting when the ring gear has the tooth counts stamped in?
  8. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    I'm running 33 12.50's on 10 inch rims, lots of rubbing, well, that's good to know that they are supposed to be like that.
