Spring rate on stock rear springs?
Discussion in 'The Garage' started by eldon519, Apr 2, 2003.
  1. eldon519
    eldon519 1/2 ton status
    May 27, 2002
    161
    Kennesaw, Georgia
    Does anyone know the spring rate on a set of stock rear Chevy springs for a K-5? Also, is it the same for a K-10? Also, how is axle wrap with these springs and a big tire, big horsepower rig? Thanks for any help.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think most springs are stiffer than 1st gen springs but hear is the info on my springs
    4 leaves
    7.88" free arch
    226 lb/in
  3. eldon519
    May 27, 2002
    161
    Kennesaw, Georgia
    Are the second generation springs alot stiffer or is it not that noticeable? Also, how is axle wrap with such a soft spring?
  4. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    All I know is that some springs I got off of a 73 K5 had one extra leaf (one shorter than the shortest on mine). I don't know if this applies to all K5's or was an option but I would assume that most 2nd gen springs are stiffer as a 1st gen K5 is lighter than a 2nd gen.
    Also somewhere around 86 they started using some softer springs. Some 1st gen guys have swapped them in and say they are much softer than a stock 1st gen spring.
    I have no problem with axle rap or wheel hop.
