Spring rate?
Discussion in 'The Garage' started by DesertDueler2, Jan 4, 2007.
  1. DesertDueler2
    DesertDueler2 1/2 ton status
    Dec 25, 2004
    132
    Chandler, AZ
    Does anyone know what the spring rate is for the rear springs of trucks, or K5s? Preferably say a 87 K5 with 52s, or a 3/4 ton truck with 56" Springs.
    Dan
  2. iwaxmyjimmy
    iwaxmyjimmy College web wheeler Premium Member
    Nov 3, 2006
    2,802
    34
    Greenville NC
    dunno the caculator for it. but its determind by the lenght of each leaf, thickness, and number of leaves .
  3. DesertDueler2
    Dec 25, 2004
    132
    Chandler, AZ
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Leafs aren't linear in spring rate. The weight/force needed to compress the first inch will be less than the weigh/force needed to compress them the last inch.
    That being said, measure the ride height at a point like the center of the fender opening lip. If you're really anal about this, put some masking tape with a mark on it so that you measure in exactly the same place everytime. Stack weight directly over the axle until you get one inch of compression. If it's not over the axle then the weight is leveraged & the math gets uglier. Weigh all the pieces/chunks and divide by two to get the effective spring rate.
  5. DesertDueler2
    Dec 25, 2004
    132
    Chandler, AZ
    Well, I am getting ready to do coils in the back, and want to keep with the same spring rate more or less.
    Dan
  6. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    id go a with a long soft coil just for a lil more flex.maybe something from the front of a je*p TJ or cherokee. maybe something along the lines of a 6-8 inch spring. but thats my own opinion.
  7. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    I wouldn't even mess with stock application springs. With those you have no control over spring rate.
    Use coil-over coils. You can get them in a variety of different spring rates, and as long as you haven't marked them most vendors will exchange them for different rates should you not get exactly what you wanted on the first try. There are commonly available springs for 2.0" c-o bodies, 2.5" c-o bodies, and 3.0" c-o bodies. If you expect to need a really long coil then use springs for one of the bigger c-o bodies as they will be a larger OD.
  8. DesertDueler2
    Dec 25, 2004
    132
    Chandler, AZ
    In the back of the spring books it tells you the spring rate of each spring and if it is variable or not. SO using a stockk aplication should be fine for me. If I could afford coilovers I would, but so far I have $30 into my project. It is on 3/4 tons already, have the stuff to either propane inject a big block, or have a complete TBI SBC with an aftermarket harness. I just cant see spending $1000 on a set of coilovers, or atleast not at this time. Maybe when it gets rockwells:D
    Dan
  9. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    I'm not talking using coil-overs, just their springs. Those springs come in 25 to 50 lbs rate increments allowing you to dial in your exact spring rate.
  10. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    avalanche engineering has them (coil springs)
