spring rate ?
Discussion in 'The Garage' started by k5 krawler 50, Apr 16, 2007.
  1. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    i'm going to purchase a set of lifted 52's for the front of my rig, and i can get a decent deal on a set of the pro comp springs. Now my question is that summit lists the spring rate at 280lbs/in., and i was wondering if that was enough for up front? I think tuff country springs are 295lbs/in. but i'm wondering what you guys think about running these up front? I have a small block, and no winch yet, but do plan on putting one between the frame rails sometime soon.
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    TC EZ ride 4" front springs have a 325 .lbs rate. Higher for the 6" and HD of both.
  3. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    well, i wonder if the pro comps are to soft for the front?
  4. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Yeah, that's the question, isn't it. hard to say. There are mixed opinions of stock 52's, up front. I don't know what the rate is on the stock ones. I finally chose to get some TC EZ ride 6" springs, and will relocate the rear mount for the travel/flex.. while still having a spring that I know won't be crazy soft for the road. Seemed like a plan to me, but don't know how the results will be, yet. I was also worried about tr/dl contact with my ORD high-steer.. so it seemed like a good set up to go with.
    I'm sure someone who's running something like that up front will chime in with some actual results. Good luck.
  5. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    thanks man, i appreciate the input, it is hard to say, and i guess if i need to fab up a track bar after some testing then that is what i will do.. thanks again.
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im going to be running 4" lifted 52's up front with the overload removed. that should give me about 7" lift or so which is exactly what im going for. all of TC's 52's have the same spring rate, on their site it says 405.
  7. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    hmm.. i wonder if i should just stick it out for the tc springs.. 280lbs/in. seems really soft to me..
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    which ones are 280? the 6" front TC's are 295
  9. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
  10. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
  11. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    i went on pro comps site, and they listed their spring rates at 342lbs/in. for the 6" lift.. i think summit has their stuff mixed up.. any how, that is a little better desirable rate i think for the front.. thanks for all the help and input..
  12. dreadstealth
    dreadstealth Registered Member
    Nov 8, 2006
    43
    fountain CO
  13. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    from the TuffCountry website:
    GM 1/2 & 3/4 ton 4wd 73-87 EZ-Ride 6" 4 465 18670
    i thought on here they were recorded as 295, guess not.
  14. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    Tuff Country "EZ-Ride" (TCI-C4M)2953
    my b, i was citing TC's 3" lift spring spring rate:doah:
  15. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Some time ago I posted the rate & Rancho p/n for a 4" Pre-runner spring that is not listed under the application, only in the numeric listings. Just tried to find it for reference & can't. Wish I could as those springs ride extremely nice & it'd be nice to have that rate number for comparison.
