Spring Rates?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChevBlazin, Mar 18, 2002.
  1. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    How much does the advertised spring rate really affect the ride of a truck? I currently have 4" pro comp lift springs on the front of my blazer rated at 520 lbs/in. The tuff country "Ez Ride" 4" springs are rated at 295 lbs/in. I am looking for a softer ride, right now I am runing a single shock at each wheel also. Will switching to these springs make a big enough deal to justify buying them?
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Yes it will. It will make it ride like a caddy compared to yours.
  3. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Ive got the Tuff Country EZ's on mine. My ride is one of the best things about my truck. It does ride very well. I say ditch the stiff ones....
  4. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    For a 4” kit, 295 lbs/in is not enough. The spring travel is too short and the axle often goes in the bumpstop. But the Tuff Country HD seems quite good to me.
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Spring rate is probably the biggest factor in ride quality, assuming the other parts are not frozen up or something. The softer the spring the easier it will be to deflect so it will help isolate the sprung mass (you) from what happens to the spring mass (tires and axles). Too soft is a little relative, a good example is stock wagonneer I drove for a bit. It had really soft springs and rode GREAT as long as the bumps were little. You could drive over smaller potholes and washboard roads fast with no problems but if you hit something big it bottomed out and hurt. Stiffer springs would have helped prevent the bottom out but given a rougher ride on smaller stuff.
    The way to get away with great ride on all terrain is to use a lot of wheel travel. The more bump travel you have the bigger stuff you can hit with soft springs and not bottom out. That's why a custom long travel leaf or other suspension works so well, you can deflect a long ways real quick to soak up bumps.
    To get away from the theory and answer your question, the TCI EZrides should ride a good bit better than the stiffer springs. The TCI HD's will be a step stiffer but I've been around a couple trucks with them that rode pretty well even without the extra weight to hold them down.
