spring ?'s
Discussion in 'The Garage' started by mtnman210, Jul 7, 2005.
  1. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    Ok maybe I'm being lazy and can find this out by searching.....
    I've been reading all about swapping 52's, 63's, stocks, front to back, back to front etc. :dunno: :dunno: Can someone give me the edited verion on what the different lengths are, which ones are used for what, and why you'd swap in certain ones, and where to put them when you do. I'm not looking for the complete write up just simplified overview on the subject.
  2. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    52" = 73-87 c k body rears 1/2 ton-some 3/4 ton
    56" = 73-87 c k body rears some 3/4 ton and all 1ton
    64" = 88-up c k new body rear all 1/2-3/4-1 ton same just more leafs and thicker steel
    longer = more flex and smother ride. also stock 52"s swaped in to the front is cheap easy 4" lift. then some use 56" in front for more flex. and the 64" is used in the rear for a lot more flex. this all said the longer the leafs the more axle wrap can happen. hope this helped you.:wink1:
  3. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    thats perfect thanks.
    I just needed to get an idea of what/why everybody was doing---it was getting confusing. I get it now.
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    glad i could help out.:rolleyes:
