spring shims
Discussion in 'The Garage' started by mouse, May 10, 2004.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Wheres a good place to buy springs shims. My 4 inch TC springs didn't come with any and the front u-joint on the rear shaft is close to being maxed out - no vibes though even up to 75 mph.
    /forums/images/graemlins/k5.gif
    Thanks. /forums/images/graemlins/peace.gif
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i believe a member here named "tony p" makes & sells them.
  3. 77 Mud Buddy
    77 Mud Buddy 1/2 ton status
    Oct 31, 2002
    228
    Austin, TX
    Note, I had some aluminum shims for a short time. With in 4 Months they were cracking and pieces were falling out between the spring / axle. If possible I'd try and find steel shims.
  4. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    4wheelparts has em. They had a choice of 6 degrees or 8 degrees. Pretty cheap but they're aluminum so you gotta use em correctly ( with center bolt through the shim) or they'll split. Good luck.
  5. 85 blazer
    85 blazer 1/2 ton status
    Feb 12, 2002
    118
    Avoca NY
    Mine did the same they broke out so I cut the perches set my axle where I wanted it and rewelded the perches NO MORE SHIMS!!!!!!!!!!!!!!!!!! Now if I could only quit breakin the darn Dana 44 Axle shafts LOL!!!!!!!!
  6. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    this place carries steel shims JKW-OFFROAD &
    BlueTorchFab just a few i can think of off the top of my head. /forums/images/graemlins/thinking.gif
    nate /forums/images/graemlins/k5.gif
  7. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Thanks, I'll give them a shot. /forums/images/graemlins/waytogo.gif
  8. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    TonyP, he'll take care of you...
    These are D60 shims and top plates he made for me, but he can make what you need. /forums/images/graemlins/waytogo.gif
    Clicky HERE>>> TonyP
    Byron
  9. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    I had some steel shims that came with my lift. Two weeks ago I pulled the remaining pieces out. They were crumbled. But I crushed a set of lift blocks a few months back too.
