spring size differences
Discussion in 'The Garage' started by big_truxx, Dec 26, 2004.
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    whats the difference between 1/2 3/4 and 1 on springs both front and rear? are 1/2 & 3/4 52" rear and ton 56"? and is the front 48" on both the 1/2 and 3/4 and the ton bigger or are they all the same on the front?
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    all frts are 48", rear 1/2 got 52" or 56". all 3/4 & 1 ton rears are 56" this is true on the 73-91 solid axle trucks
  3. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    actually i think most 3/4 ton trucks got 52" rears. i have had 5 of the 73-87 year range and all had 52's. i had 2 3/4 ton suburbans and both had 56's.
  4. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    sweet thanks! i love info. i spose im kinda the knowledge monster. :haha:
  5. dremu
    Feb 27, 2000
    15,967
    458
    East of San Francisco
    Note that you're a special case, as crewcabs, even 3/4's, all have the 1-ton frames. At least, this was the case in the 70's, donno about your newfangled ones :D
    Easy thing, measure the spring perch spacing on your rear axle.
    -- A
  6. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    i had heard that all the crew cabs did have the one ton frame. but its cool that all fronts are the same. whats the difference in the 1/2, 3/4 and ton front springs? each have a leaf more than the other?
  7. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    i think 1 tons had 3" wide springs, front anyways. 1/2 3/4's had 2-1/2
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    All of our trucks have 3" wide front springs. Aftermarket lift springs are 2 1/2".
    1/2 tons 52s or some had 56s
    3/4 tons, most 56s, some 52s
    1 tons, 56s
    Front springs can be two, three, or four leaf from the factory. My K10 originally had 3 leaf front springs because it had that listed as an option.
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    all stock front springs are 3" wide. there are 2 leaf packs and 3 leaf packs, both can be found in 1/2 and 3/4. i think the 1 tons got 3 leaf only, haven't seen to many of those to know for sure.
    the rears are 52" and 56", 52s are found it blazers 1/2 ton trucks/burbs, some 3/4 ton trucks and some 3/4 ton burbs
    the 56" were found in all 1 tons and some 3/4 ton trucks and burbs, it depends on the GVW of that particular vehicle.
    i have seen 52" 1 ton springs made specifically for tow trucks
  10. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    sh%t sorry!
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    84 chevy k10 has it right
    alot of 70s 10 series got 56" in the big 10 and heavy half days
    late 70s k20 alot of them were 52" rears
  12. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    so where'd the 63 inchers come from?
  13. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    63" springs come from 88 (new body style) and newer trucks
  14. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Thread hijack!
    Where can I find specs on spring rates and centerpin alignment etc? I am thinking obout having some springs made for the rear. I have Ferd 57's and want something a tad stiffer and the center pin hole in the right spot without having to drill another in it.
