Spring Things...
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Steve_Chin, Mar 15, 2001.
  1. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    From what I've read, the front axles from a Gen2 Blazer will swap into a Gen1, but will the front springs swap in without any problems?
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    Steve,
    the springs will swap in but they will make the axel sit back about 1/2" to 1". It will not be a problem with smaller tires but once you start putting 33 or bigger you'll notice the rubbing while turning.
    ARQ.
  3. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    No, the front springs on '73 + are longer (2" ) than the 72' trucks. As for the axle, 10 bolts bolt in no problem. My lil' bro' runs a 19 bolt in his '70.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  4. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    A "19 Bolt" ???? Thats got to be huge. [​IMG]
    See Ya,
    Keith
    [​IMG] Born to Drive My K5 [​IMG]
  5. californiak5
    Oct 25, 2000
    820
    Hey Steve,
    What I believe to be true (could be wrong) is that just about all of the front chevy straight axles are interchangeable. The rear axles are interchangeable also you just need to move the spring pads and the shock mounts if your donor truck is a 1/2 or 3/4 ton. The 1 ton axles will bolt right up to our trucks thou. If you have a 73 and up K5 the rear 1/2 and 3/4 ton axles will bolt right up and you will have to move the sring pads if you get a axle from a 1 ton. At least thats what I understand, anyone else can jump in at anytime. As far as the springs go, I am not sure.
    See Ya,
    Keith
  6. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    I have a freind who actually just put a set of 73- up springs on his 72 blazer. 10 inchers. He said the rear eye of the spring sits back around two inches farther than the stock ones.
    [image]http://albums.photopoint.com/j/View?u=1328774&a=9975627&p=33244094[/image]
  7. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    Ok, so my typing leaves a bit to be desired. [​IMG]
    As far as axle interchangability, you're right.
    Pete
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    Bolting in a 1976 10.5" 14-bolt rear axle into my 72 is gonna require movin the axle tube pads, correct ??
    At least thats what I have been told, anyways.
    Where do I find new spring pads to fit the bigger (3.5") tubes ?
    Im not gonna want to reuse the old ones once they are cut off....
    '72 K-5 4x4, CST, 3.07, 4 speed, NP 205, 31' x 10.5", Olive green and primer, rusted out, rice smasher!
  9. Cliffy
    Cliffy Registered Member
    Oct 8, 2000
    99
    South Lakewood, CO....... FINALLY!!!
    your local 4x4 shop should be able to get you some for around 12 dollars or a local parts supplier could charge you up to 20 dollars. Just ask for spring pads for a 73 and up FF14 bolt.
    Coil sprung 71 blazer.
  10. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    A 3/4 ton 14 bolt will require you to move the spring perches but a 1 ton 14 bolt will bolt right up without moving the spring perches. For the perches there are a few companies that make them and your local 4x4 shop should be able to order them i think they are around $30-$35
    <A target="_blank" HREF=http://WWW.SMP.COLORADOK5.COM>http://WWW.SMP.COLORADOK5.COM</A>
  11. californiak5
    Oct 25, 2000
    820
    Check out what Glenn did on his 12B here <A target="_blank" HREF=http://www.off-road.com/chevy/tech/perch/>http://www.off-road.com/chevy/tech/perch/</A>
    I need about another 1.5" of lift in the rear so I think I am going to do this to my 14B with a xtra .5" on the spring perches and then get the ORD 1" add a leafs.
    See Ya,
    Keith
  12. Steve_Chin
    Mar 6, 2001
    1,126
    That's a pretty cool-looking mod, but it looks very heavy. I would guess that most don't care about that, though. One thing I would add to those perches is drain holes in front of and behind the axle tube...
