"Springer" Shackles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rampage, May 8, 2001.
  1. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    \"Springer\" Shackles
    Has anyone every heard of "Springer shackles" or know of anyone who uses them. Was considering getting these but would like some input (pros and cons).
    <A target="_blank" HREF=http://www.users.qwest.net/~ruthspear/index.html>http://www.users.qwest.net/~ruthspear/index.html</A>
  2. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    Re: \"Springer\" Shackles
    I e-mialed the guy a couple of months ago for prices and more info and never heard back from him.
    Guess he dosn't want to make any money.
    <A target="_blank" HREF=http://WWW.SMP.COLORADOK5.COM>http://WWW.SMP.COLORADOK5.COM</A>
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You know, that looks really simple to make and it would be a nice solution for those who want to go to longer springs. You get a shackle flip without messing with the hanger, plus longer/flexier springs, plus the droop of a "goofy leaf" without having to expend energy to bend the short spring down. Other than maybe a cradle to hold that thing in position (for lateral stability) when it is locked up against the frame, looks like a nice idea.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  4. rampage
    Mar 20, 2001
    2,261
    73
    I hadn't even thought about the lateral movement, thanks. I was also thinking that a pin to lock it in place so it doesn't flex on the road might be nice too, just a simple pull of the pin would give a lot of flex.
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I saw that sort of deal on a Ramcharger in 4 Wheeler last year.For the arm the guy used the main leaf from leaf a spring pack (the one with the eyes on both ends),cut the ends off,then welded the 2 ends together.What he ended up with was an arm that looks about 12" long with eyes in both ends.Its pretty much like yours other than the arm and he didnt have a way to lock it down when he didnt want it to work.Im gonna do this to mine when I get the time.Its a great idea and its cheap.
    Proving once again that man CAN live on beer alone
  6. NewK5Guy
    NewK5Guy 1/2 ton status
    Mar 2, 2001
    556
    Alexandria, VA
    That does look nice. A cheap effective way to add flex without too much modification, but what about streetability? Now you have a double rear joint. Isn't that thing gonna slap the frame every time you hit a pothole or does it have a locking mechanism for street driving?
  7. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Another thing the guy did on the one I saw was that he moved the shackle hangers foreward on the frame 8 to 10" so he could use his stock legnth springs.
  8. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Hey I've talked to Marvin quite a bit and even phoned him on this shackle setup. Eventually I plan to make something similar. Is he selling it as a kit now? He's a really good guy it seemed and gave me a lot of pointers. He uses 56? " Ford F150 springs. I have a set here at the house, was going to do the swap and then decided against it for now. I imagine the foldability of the shackles is much like revolvers which tend to never extend on the street unless all the weight is out from under that tire. That's hardly never unless you're jumping railroad tracks or climbing guardrails. (This is just what I've heard about rotating type shackles). Good luck to ya and keep trying Marvin, he's a stand up guy it seems like.
    Durant, Ok
    The road goes on Forever and the Party never ends!
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, if you add the cradle, it would be trivial to also add a pin to lock it into place when in the cradle. Then, it would be no different than the stock long spring setups with a shackle flip. Definitely beats moving the rear hanger back to put the long springs on.
    Bad Dog
  10. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    I talk to the guy on a regular occasion and I've actually gon 4wheeling with the guy, the truck is awesome for flex and Marvin is Awesome also..he gets about 20-24 inches of flex. He's comeing down to El Paso (hes from here) and im gonna go 4 wheeling w/ him again and I'll take pictires-- he just sent an e-mail to me about a flip for an ORD conversion and I'm probably gonna use it so I'll give some info about that. I've got his home and business phone number and E-mail address if you would like some more information. And when I go wheeling w/ him I'll send a post.
    Not all Rednecks drive ugly trucks---umm, nevermind <A target="_blank" HREF=http://jimjim.coloradok5.com>http://jimjim.coloradok5.com</A>
  11. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I found the one I saw,its in the Feb. 2000 issue of 4W&OR pg. 70&72 and they got a good shot of it.
  12. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    i thought the goofy leaf idea had finally gone out of style, guess not. that looks like a zero gain mod to me, except in this ap it allows longer springs but if you have to drill the frame for the overload bumpstop you may as well be drilling 1 more hole and relocating the rear perch ( that assumes a ford style bumpstop that uses 3 holes)
