Springs and levers for Caddy calipers -- part # inside
Discussion in 'The Garage' started by dremu, Sep 24, 2006.
  1. dremu
    Feb 27, 2000
    15,954
    444
    East of San Francisco
    For those buying Caddies off the shelves, the missing hardware can be had as follows:
    You'll need return springs for the parking brakes. Dorman #071-005 is a very close match to the original.
    http://www.dormanproducts.com/cgi-bin/vm91corp30r/item-dtl.w?sid=0x01373a1d&item=071-005&icrid=&clt=hwrap1&vsrch_str=071-005&vsrch_brand=ALL&vsrch_cat=ALL&st_amount=&end_amount=&start=&vfrom=&prev=&vnext=&category_list=:0
    Dorman is also Motormite, the "Help!" people ... my local quality parts house carries their stuff, or can be had from your local NAPA:
    http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=BK&PartNumber=6151100&Description=Clutch+Return+Spring+-+General+Purpose
    Here's a pic:
    http://www.slosh.com/dremu/caddy-calipers-installed-1.JPG
    showing where to bend the long end.
    You'll also need a lever, which can be made via any one of a number of methods, however as the picture shows, I used 14mm wrenches, which conveniently have the correct hex end on them already. They are, however, a bitch to drill (fricken hardened tool steel, grrr :mad: ) Even with my drill press I nuked a coupla bits doing them.
    You could cut your own from flat stock if you can make a nice 14mm hex hole with a file. I am not that patient :doah:
    The bracket to hold the parking brake cable is left as an exercise to the reader, as it depends on your cable ends. In the end I welded a tab on and folded it over:
    http://www.slosh.com/dremu/caddy-calipers-installed-4.JPG
    laid the cable in and then shut it ... IIRC, the vise-grips didn't do it, so a mini-sledge was involved :rolleyes:
    -- A
  2. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Or you could just buy them from TSM, which I did, and everything goes on sweet in minutes.............:D
  3. dremu
    Feb 27, 2000
    15,954
    444
    Oh yeah, like your working parking brake :rolleyes: :whistle:
    I'm providing a budget alternative for those not able/willing to throw money at the problem :deal: :D
    JMS is right, though... it's about a balance between bought and built. Some of us tend more towards the building, either 'cuz we're poor, or cheap, or just like building stuff. (Me, I'm all three :haha: )
    -- A
  4. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    The brake works great, it is the four mile long cable that is causing the problem. Sometimes time is money though. For me, I can go work a little extra, and pay for something rather than spend long hours fabbing something up. For someone who doesn't have that option, fabbing your own is a good alternative.
