springs & axles
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by RGV72BLAZER, Feb 2, 2006.
  1. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    I got a few questions boiling in my mind. 1* what's the difference between a 69-72 and 73&up rear leaf spring? width? i believe they're all mostly 52" springs if i'm right. for example, would a rear leaf spring made for an 87' Blazer work on my '72 Blazer? 2* what's the wms for a gm d60? THANKS.
  2. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Rear leafs are the same for all Blazers.
    I've got a set of '89 springs on my '72.
    The later model springs are WAAAAY softer than the 1st Gen stockers....It's a cheap way (almost FREE) to get better flex.
    :usaflag:
  3. RGV72BLAZER
    Jan 23, 2006
    2,425
    so there's no diff? i ordered a shackle flip and HD shackle from ORD for my '72 and have a set of springs from a 73&up gm, so everything would bolt up like i was using '72 springs? thanks.
  4. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Like I said, in the rear the spring lengths are all the same. :wink1:
    Up front it's a different story. Stock 1st Gen springs are only 44"...later model ones (73+) are at least a couple inches longer than that.
    I'm running the ORD shackle flip, HD fron shackles, and the '89 rear springs....check some of the other threads here for some of my flex pics. You'll be surprised at what it possible without going to a super-exotic suspension setup.
  5. RGV72BLAZER
    Jan 23, 2006
    2,425
    sounds good, thanks :bow:
