Spun bearing in 14FF hub
Discussion in 'The Garage' started by Masher, May 16, 2003.
  1. Masher
    Masher 1/2 ton status
    Mar 7, 2002
    123
    SW Michigan
    I'm putting my 14FF back together and was putting new bearings in the hubs and on one, the inner(big) bearing race spins. It looks like the PO had grenaded a bearing because the inside if the hub is all scored up. Can I just put some green locktite or sleeve sealer on the race and tap it back in?? Or is there something else I should do?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I would replace the race myself then use something to help it stay in place /forums/images/graemlins/thumb.gif
  3. Masher
    Mar 7, 2002
    123
    SW Michigan
    The bearings and races are brand new. What is the best to use to keep it in place?
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    That i can't answer, i've never had to use anything. Someone else chime in /forums/images/graemlins/thumb.gif
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Sometimes you can repair by ruffing up the surface with a punch and using stud and bearing mount loctite. Depends on how much play space you need to 'fill'.
    In this case I would replace the hub. Cheap and avaialble. Worth every penny for peace of mind!!!
  6. Masher
    Mar 7, 2002
    123
    SW Michigan
    The race starts going in nice an tight but when I get down where it supposed to seat it spins pretty free. Where is the best place to get a hub?? Do the local parts stores carry them or it like a dealer or boneyard part??
    Thanks for the quick info!
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    On a part like this, which is very important and valuable to insure your safety and others, too, I would replace the bearing hub for a better one. Just simply post a thread in the For Sale/Wanted forums and ask for one. I'm pretty sure someone on this site will have one to sell to you for pretty cheap. /forums/images/graemlins/wink.gif
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Well, im not 100% sure for 14b, but i know on 44's and 10b's this is common and when it happens you get new hubs. Sounds like thats what you should do!
  9. Masher
    Mar 7, 2002
    123
    SW Michigan
    Thanks for the advice. I'll start looking around for another hub. Anyone in the 'garage' got one??
  10. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    If you can't find one closer, I've got one.
  11. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    How do the axle tubes look? You should inspect those also.
