"sputter sputter" (also pops the oil filler cap off) some ideas?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddin4fun, Nov 12, 2001.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    \"sputter sputter\" (also pops the oil filler cap off) some ideas?
    My blazer isn't feeling too good [​IMG]. It was low on fuel and it got real humid overnight and the temp dropped too before I filled it up(just some background info). So, I filled it up last night. This morning on the way to work, the throttle response started sucking. Then, while holding a constant speed, it would sort of gallop. Not bad, but I could tell. When it's in D and stopped, the idle sucks. It's not missing, just rough. I put some additive in the tank thinking that maybe I got some condensation or bad gas. I've been drivng it around for a while and it hasn't helped. I'm wondering if the distributor is advancing properly. Is there a good way to check it? Also, it keeps popping the filler cap on the valve cover. Why would it do that?
    Peace and stuff [​IMG],
    Muddin
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer>www.geocities.com/muddin4fun79blazer</a>
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    Re: \"sputter sputter\" (also pops the oil filler cap off) some ideas?
    <font color=blue>You could check the timing advance with a timing light. Bring the RPMs up and watch the light on the harmonic damnper advance. The popping filler cap leads me to belive there is excessive crankcase pressure (clogged or closed PCV).
  3. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    the cap is a cheapo. I might get another one and just see. The motor and everything is brand new along with the pcv.
    Muddin
  4. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    I'm with Chris on the PCV valve causing excessive crankcase pressure. As for the distributor, you could remove the cap and see if the centifugal weights are sticky or if they move freely.
    It actually sounds as if the carb is leaning out...giving you a bad idle and a surge at cruise RPM's. Vacuum leak maybe?
    Maybe the vacuum to the vacuum advance has come loose?
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I agree. Pull your PCV valve, and see if it rattles. If it does then its ok. Also check all your vacuum lines and make sure they are all hooked up right. One time I change my spark plugs, and when I went to drive it it ran like s*it. I thought it was the plugs at first, but then I went over my vacuum lines, and I had knocked one off and didn't notice it. Plugged it back in and it ran fine.
    My Chevy isn't broken, its just out of gas.
  6. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    man muddin with that nice new 383 I hope nothing serious is wrong... [​IMG]
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I hope it's nothing serious, but it sure sounds like there is some serious blow-by somewhere in the engine. [​IMG] Not the sort of thing that should be happening on an engine that fresh. [​IMG]
  8. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    I'm gonna check all the easy stuff first. If there's something wrong with the engine, it's still under warrentee [​IMG]
    I'm gonna pull the plugs tonight also to see what they look like. If it was a motor problem, it would be in the valves correct? Which would possibly coat the plugs with oil? Is that correct?
    Muddin
  9. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Do you have an oil pressure gauge? I read in one of the mags recently about how if you use too much RTV to seal up your engine gaskets, you could end up blocking oil passages....that would cause HIGH oil pressure as the symptom......maybe blow the cap off too?
    I don't know if this could be what's happening, but in the article they pulled the covers off, carefully cleaned the RTV out of the passages and were lucky enough to have the engine work great after that.
    They did mention that using excess RTV sealer on a diff cover is no big deal, any extra there gets "chewed up" really quickly by the ring gear and pinion......unlike what happens when it starts circulating in the oiling system of the engine.
    -Greg72
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    Somethign is definately causing too much crankcase pressure to blow off the filler cap. The PCV is probably th culprit.. But on a new engine I imagine you used a new pcv valve.. And being that new there is probably somethign wrong if it is clogged!
    Mike
    <font color=green>"1024x768x256... Sounds like one mean woman."</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  11. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Her PCV may be fine but if its not getting vacuum it wont be doing a thing.
  12. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    I'd suspect the vacuum to the pcv is unhooked or damaged. This could explain the cap getting blown off and the bad idle and driveability due to a vacuum leak...
    Rene
  13. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    that's what I'm gonna check.
    How strong is that vacum? Can I take the hose off the carb and put my finger over it and feel it?
    Muddin
  14. dogman
    dogman 1/2 ton status
    Oct 31, 2001
    213
    California, Santa Clara Co.
    I'd throw a new fuel filter at it just for ducks, they're cheap; and have solved many problems.
    gas-n-sledge from the bottom, will clog.
    this is not your problem, not with a new motor. you shouldn't be getting oil out of the valve stems yet..
    but if your checking the valves out, when the covers are off. turn it over, put you hand on the rockers. are they going up and down the same? its a crude way to tell if you have a flat cam problem without measuring them.
    good luck.
  15. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Yes...should be able to hear it too.
    Rene
  16. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Thanks guys for your help. I'll sheck it out tonight and give an update [​IMG]
    Muddin
  17. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Well...the plugs were fuel fouled. Swapped them out and it runs great! No oil or anything. I still don't know wy the oil cap pushes out. The pcv is in good shape, no leaks, and the carb is creating the vacum. I'm gonna try a different style to see if it's just the design or something. They are cheap valve covers and the cap was also cheap. Maybe they don't mix well?
    Muddin
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The carb doesn't create the vacuum. :) It's just where you tap into it.
    Either way, I'm glad to hear it runs better again. I'd try to find the source of the fuel fouled plugs. Is your choke sticking?
    Tim
  19. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    Glad to hear you solved the problem. If your plugs foul again, you might try going to the next higher heat range.
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
  20. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Re:
    I meant by the carb was sucking thru that hole...thing...there...anyway...
    It was running like the same thing again this morning [​IMG]. I checked the choke last night and it's not sticking and it's adjusted right. I'm thinking that it's not warming up (plugs indicated running rich which could be the choke because it's not warming up and it basically is running like it's not warmed up.). So, I'm going to get a new thermostat. The temp guage is showing on the cool side, so maybe that's it. I'll put that in tonight. Work sure does get in the way alot! [​IMG]
    Muddin
