Sputtering at low rpm's?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by OneInTheSun, Jul 15, 2000.
  1. OneInTheSun
    OneInTheSun 1/2 ton status
    160
    Pittsburgh, PA
    Sputtering at low rpm\'s?
    After my 85 k5 (305) sat for a couple of months in the garage to get patched up (I'll post pics soon), I took it straight to the Bloomsburg 4 Wheel Jambo (4 hours away) - it drove up, around and back just fine. The night I got home, I let it sit for an hour and when I fired it up again, that's when the problem started. It idles OK and is alright at higher rpm's, but when I feather the gas it sputters (does it in park, neutral and in gear). After sitting overnight, it's OK for about a minute in the morning, but as soon as the temp gauge gets a little over 100, it acts up. I just changed the plugs and fuel filter, and I'll probably do the cap, rotor and wires. Any ideas?
    <font color=blue>Rob
    85 K5</font color=blue>
    [​IMG] 24 beers in a case, 24 hours in a day - Coincidence?
  2. Glenn
    Glenn Registered Member
    87
    North Kingstown, RI/USA
    Re: Sputtering at low rpm\'s?
    Try unpluging the hose on the egr valve and then see if it still does it. If it stops then its time for a new one. It happend to me too and thats what it was.
