square driveline?
Discussion in 'The Garage' started by ryaninc, May 1, 2007.
  1. ryaninc
    ryaninc Registered Member
    Feb 13, 2005
    45
    Salem, OR
    Ok so I want to make a square driveline, I know the pros and cons. any of you made one? If so How? two pieces of square tube that fit inside oneanother 1/8 or 3/16 wall? do you weld to orig. tube or just to the yokes? any tips or hints would be helpful.
    Im trying to do this by Fri so I can wheel on Sat.
    Thanks Ryan
  2. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    2.5" x .25" WALL AND 2" X .188" WALL. depending on what front shaft you have' you can grind it down to fit inside the square tube. it'll help hold it betetr and keep it lined up. search around, there is lots of info.
  3. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    One friend of mine had the yokes turned down to retain their circle shape until they fir inside the square- That ensured the yokes remained centered inside the square.
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I use 2" .250 for the big tube and then 1.5 , .188 wall for the small tube. I prefer to not used seamless tubing as it is substantially more expensive. You may have to spend some time with a grinder to get the shafts to slide but it works way better ( I have done both) As far as the yokes go all I have ever done is cut em off and eyeball them on. It helps to have more than one person around though.
