square key
Discussion in 'The Garage' started by wraenking, Jun 15, 2004.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    i need one for my 3'4 ton 14 bolt
    it didnt have one when i removed everything, but im guessing i need one. anyone have a part number so i can go to napa?
    thanks
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I've never seen a square key on a 14FF. I think you are talking about the keyway at the end of the spindle? There is a flat washer that sandwiches between two lock nuts with an internal tab that fits that keyway you see. That is the system that locks everything together.
  3. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Are you talking about the fill plug?
    If so, just use your 3/8" drive ratchet withOUT a socket attached.....you actually might need to use an extension to actually reach in there.
    /forums/images/graemlins/thumb.gif
  4. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
  6. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    There are 2 different wheel end set ups for a 14 bolt.
    The single nut which just has the nut, lock tab (square key)and a tab retaining clip.
    The other has 2 nuts, one to set the bearings and the other as a lock nut with a lock ring between them.
    If you have a single nut wheel end there has to have been a lock tab.
    That's what keeps the nut from backing off.
    Without the tab it would not take long before the nut backed off, either causing a blown wheel seal and a big goopy mess, or comes off completely and the whole shiterie departs from the rig... axle shaft and all.
    Napa should have them, just tell them what wheel end you have and if the guy isn't a total dork he should be able to hook ya up with what ya need.
