Square tube driveshafts WORK !!!
Discussion in 'The Garage' started by denver75k5, Aug 4, 2003.
  1. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    I had made up a couple sqare tube spare driveshafts and after sending my $400 front shaft into little pieces this weekend I got to try the square one, let me just say that they are VERY strong, I got up on a couple rocks with it and it diddent even dent /forums/images/graemlins/grin.gif and for $15 for ends at the junk yard it's well worth it /forums/images/graemlins/laugh.gif
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    yup, square fronts are great for crawling.
    I am contemplating making a square rear for trail use only. Get to the trail, drop the "driving" drive line and bolting up the "trail" (square) driveline. /forums/images/graemlins/thinking.gif
  3. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Hummm...
    What size and thickness square tube?? 2"x1/4"??
    What junk yard parts and what from???
    I gotta make one too!!!! /forums/images/graemlins/thumb.gif
    Jerry /forums/images/graemlins/smile.gif
  4. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    is there any reason why you couldnt use a square driveshaft all the time? would it vibrate to much? /forums/images/graemlins/thinking.gif
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    from what i hear, they are impossible to balance
  6. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    reciever tubing stock
    proper u joint flanges cut off a driveshaft to fit your yokes.
    do a search on pirate for more of the skinny on the situation. /forums/images/graemlins/grin.gif
  7. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    seems to me that a square tube would not handle minor encounters with rocks or stumps as well as round tube,for the same reason that tires arent square.i can remember being hung up with my front shaft on a rock with all 4 wheels spining.i would be willing to bet if i had a square driveshaft something would have broke,either the shaft,or a u-joint,maybe more.also,pipe is said to be the strongest form of steel,because it spreads a load evenly.i guess thats why racecars have only round tube for roll cages.as far as it being cheap,if you could build one out os square stock,you could build one out of tube just as well.
  8. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I think there are a few other reasons why tires arent square.....Messin with ya it sounded funny /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  9. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    The square tube used for the shaft is hitch and reciever tube.
    You will break something else looong before this square tube even thinks about bending or breaking. /forums/images/graemlins/grin.gif
  10. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    no, a square tube can flat out handle more.
    I have *personally* seen a rig hung up on its rear drive line and moved" the rig over so that it can find traction.
    guy wheeled the rest of the day on it and it was fine. Show me a round driveline that can do that.
  11. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Let me guess was it the same rock that threw you off the side of the mountain a few months back? And u still can't conquer it /forums/images/graemlins/thinking.gif
  12. denver75k5
    May 15, 2001
    1,017
    I have also seen these work, after seeing them support the weight of a rig at the Kremmling rock crawling comp. that sold me on them.
  13. denver75k5
    May 15, 2001
    1,017
    /forums/images/graemlins/grin.gif Nope I found a new set of rocks
  14. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    Zakk,
    i would argue that with you all day long.if the same type of metal of the same diameter and thickness if used,round stock is far stronger.thats just a fact.not to say a square driveshaft wont work,but they are inferior.to me its simple to understand how a square spinning object, with 4 flat sides,would have a harder time dealing with rocks than a round one.i dont know.maybe i'm tarted'. /forums/images/graemlins/frown.gif
  15. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    so explain to me what happens when a round tube is dimpled and rotational force is applied to it...
    the same is not true of square tubing.
  16. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    ok,ill give you that one.it does seem like the square stock would be less likely to ding,but more likely to cause breakage if the impact is solid.
  17. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    break a pice of 1/4" square reinforced with 1/4" reciver stock inside of it?
    If your breaking that, its the least of your problems!
  18. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    If the square is so great, I'm just wondering why High Angle or any other driveline shop doesn't start offering shafts with it? hmmmmmm
    I'd say for an emergency only use, they will work. But even out on the trail having an unbalanced shaft spinning all day will help to kill your pinion bearings on both the tcase and axle.
    Personally if I want a beefy shaft for trail use I'd just run .240 wall Chromoly or equiv, but I'm sure Jess @ High Angle could chime in and explain why such is good or bad.
  19. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    because it doesn't balance /forums/images/graemlins/rolleyes.gif
    how many Atlas 5.1's have sold? 18. you know why? the masses can't use them.
    same with Square drive lines. 99% of the population is out of the running before the first bead is welded.
    this is quicky becoming a conundrum of epic proportions /forums/images/graemlins/rolleyes.gif
  20. dyeager535
    26,982
    191
    I thought the triangle was the strongest structural shape? /forums/images/graemlins/confused.gif
