square tubing for roll bar/cage?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by tp85, Apr 16, 2002.
  1. tp85
    tp85 1/2 ton status Premium Member
    Mar 14, 2002
    130
    Maryland
    Is there any reason why I have not seen any roll bars/cages made out of square tubing? Maybe round tubing just looks better.
    I'd like to make a stout cage...say with 2" X 2" X 1/4" square tubing. With my chop saw it is easy to make the cuts at various angles...much easier than notching round tubes to fit together.
  2. JoshA
    JoshA 1/2 ton status
    Apr 9, 2001
    104
    slc,ut
    I'm sure that there are people that know better than I, but I think that it is because round tubing is stronger. it stresses equally across the whole tube. I think that square tubing collapses easier.
  3. Skyetone
    Skyetone 1/2 ton status
    Apr 10, 2002
    118
    SLC Utah
    the reason that most run round is one it is easier to bend and form. With square to make a turn and go around something you have to cut and weld all the parts together. It looses strength every time you cut and weld. Thats why you see em as sliders. There strait. With round when you go around say your dash to the floor it is still one piece and will hold up to a roll. that is assuming that you haven't overbent or kinked the tube. There are alot of issues with it all. It lies in mostly that it is just plain safer to have one peice of tube thats bend a few times than alot of little pieces put together to do the same think. Been playing rock warrier for a while. just toyota style.
  4. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    hey josh where ya at in utah?
  5. JoshA
    Apr 9, 2001
    104
    slc,ut
    I'm in taylorsville... west side of salt lake
  6. Skyetone
    Apr 10, 2002
    118
    SLC Utah
  7. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    because round is just easier to fab with a bender. Square distorts with a bender or compresses on one side. Like said earlier, it's a pita to cut and weld every radius, capping and such. That said, if you're a competent welder, there's no reason that such a cage will be any less strong. Look at bulldozers and construction equipment. See any round tubing there?
    Btw, 2x2x.25 square is quite a bit heavier than 2" x .120 round obviously, but I'm sure you've thought of that.
    Here's a pic of a square exocage on a toy.\
    <a target="_blank" href=http://www.pirate4x4.com/forum/showthread.php?s=&amp;threadid=48096>http://www.pirate4x4.com/forum/showthread.php?s=&amp;threadid=48096</a>
  8. tp85
    Mar 14, 2002
    130
    Maryland
    Yeah, I certainly would not plan to bend any square tubing.
    I figured that a quality weld at square tubing joints would not be much (or at all) weaker than bent round tubing. I do plan to use 3/16 or 1/4 thickness square tubing.
  9. tp85
    Mar 14, 2002
    130
    Maryland
    Given equal wall thickness, what is stronger...2" X 2" square tubing or 2" diameter round tubing?
  10. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    I think there are different catigories of tube in square like round. Am I right? Like dom-hrew-bla-bla and bla style round tube. Can't think of all the names right now
    Thats a big variable
  11. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    In a .188"-.250" thickness you could prolly drop off the Lion's back without bending it...
    A couple things come to mind. Firstly it would be brutally heavy. 2x2 HSS square tubing with .250 wall thickness weighs in at almost 7 lbs per lineal foot. For more perspective that means a simple hoop behind the front seats would weigh almost 90 lbs.
    Next is that it is gonna be brutally ugly...never mind labor intensive.
    Lastly it's not cheap unless you already have a bunch lying around. For the difference in cost between the 2x2 tube and some .100 wall HREW round tubing you could pay for most of a budget tubing bender...
    Rene
  12. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    TP85, I haven't seen any seamless square tube that's readily available, so I'd say that for impact resistance, seamless round tube would be stronger than the square stuff, given the same wall thickness. They'd be similar in strength in static compression or tension, and round would be stronger in torsion.
  13. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I Have a square roll cage I bought from brian60's its veary stout and I will post a picture of it To night.
    Colin
