Square Tubing
Discussion in 'The Garage' started by petryshyn, Jun 22, 2005.
  1. petryshyn
    petryshyn 1/2 ton status
    Jun 6, 2004
    150
    Yorkton,Sk
    Could I use square tubing for a spring perch would it be strong engouh, also what thickness would i be looking at to use. Or is it just a better idea to use a solid block. Thanks
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Square tub is fine, I would use at least 1/4 maybe 3/8
  3. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    1/4" wall should be plenty... but overkill never hurt anyone either. ;)
    j
  4. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I used 2 1/2" x 1/4" square tubing. Then used 1/2" plate on top and 3/8" on the inside top to eliminate the zerorate and boxed the open ends with 3/8".
  5. tRustyK5
    Jul 23, 2000
    36,169
    1,367
    E-town baby!
    Once you get past 1/4" wall the rad's on the corners of the tubes becomes too much IMO.
    Rene
