Squeaking belt or pulley?
Discussion in 'The Garage' started by nad, Apr 25, 2006.
  1. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    I just got done changing my intake gasket, and I put the A/C compressor back in place on my 305. After I put the belt back on and tightened it down, I started it up and got a hideous squealing noise. My dad sprayed WD-40 on the belt and it went away temporarily, but we still can't figure out what's causing it. Could the belt be too tight, or the compressor be off crooked a bit? Would that cause this?
    Also, I got the truck out to drive it, and noticed it idles lower than it did before i changed the gasket, but it sounds like it's idling at a more healthy speed than before. But it seems to me like the motor isn't idling fast enough to turn the power steering pump to let me have power steering.
    Is it possible that my power steering pump is bad and that's what's causing the squeak and lack of power steering? Or do I need to just adjust my idle on my motor somehow?
    Any suggestions or information would help greatly. Thank you very much.
  2. ct85k10
    ct85k10 1/2 ton status
    Oct 25, 2005
    121
    Charlotte, NC
    how old is the belt i messed with mine for months and couldent keep it from squeling untill i replace the belt and wouldent wd40 make the belt slip more
    and make sure the pulleys are aligned properly
    colby
  3. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    replace the belt, then while the belt is off its a good time to check the shaft on your water pump just check and see if it has alot of play, and spin your alternator,
    sometimes the alt will squeel like a sob wheen its on its death bed
    if your steering feels responsive and with the proper fluid level it does not whine or skip then id say its ok, if anything maybe disconect your non pressure line and run a quart or two of atf though it to flush it,
    then there is the chance you over cranked the belt and the idle changed from the loss of slack you previously had since there is more load on it now?
  4. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Okay, I was out looking at my truck tightening bolts, and I noticed I forgot to attach the compressor brace that braces to the intake manifold. That could have possibly been my problem, but I haven't tested it yet, because I hit yet another, perhaps a bigger problem.
    The fuel line that is attached to the right side of the throttle body if you're facing the front of the truck, has a stripped male connector. I can't get it in there tight enough to keep fuel from leaking, and now that I got it somewhat in there, I can't get it out at all.
    This is where I get completely worried. What do I do?? Will I have to replace the entire fuel line all the way back? Any suggestions or information, please share. I'm a noob.
  5. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    dont play around with a fuel line..:(
    call up napa, and a couple others, a performance shop, etc and pay for a new line, my truck burned as the result of a fuel leak,
    between 20-35.00 should be the complete cost,
    post pics and please ask questions if you have any concerns,
  6. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    prolly a pully, get a new fuel line, and for your power steering, Its prolly your IAC on its way out.
  7. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    AIR conditioning??
  8. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,014
    848
    Pinckney, MI
    Idler pully was the case for me..
  9. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Yeah, watch that dang idler pulley....I have been through several of them myself....
  10. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    So how hard really is it to change a fuel line? I'm scared to even attempt it.
    Also, I think the source of the squeak was because I didn't have the compressor brace on. But I don't think that would effect the power steering like that. I checked the fluid and it's fine, but I'm not sure what else to check on.
    Any tips/suggestions or complication ratings on how hard it is to change a fuel line?
    Thanks.
  11. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    the fuel line will be just fittings,
    one at the base of the hard line, near the pump, a 5/8. the other near the maninifold, dont let it scare you, alot about these trucks is basic wrenching, just make sure to note how you remove things and not to use alot of force when you tighten fittings such as a fuel line,
    also if you have a line wrench, it will save you some headaches over time.
    and pick up a hanes manual at your local auto parts, about 15 bucks but for someone just getting into wrenching or mechanical stuff its a good source of info,
