Squeaking calipers (not squealing)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddin4fun, Sep 21, 2001.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    My front calipers squeak when I apply the brakes. It will do this while driving or parked, so I know it's not worn pads. What in the heck will cause this?
    '79 Blazer BTW with 10bolt front.
    If you see my truck on a trailer, call 911 cause it's <font color=red>STOLEN!!!</font color=red>
    Website link is in my profile [​IMG]
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Lara, you probably need to take the calipers off and clean up the caliper bolts. The area where the race type surface is and the spacer sleeves go into the caliper. This is the only place you would get any noise apllying the brake while it was parked!
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Well crap....
    I knew to check that [​IMG]. Thanks mang!
  4. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    It shows you in the Chilton's manual where to apply the lube at. I used white lithium grease on mine when I did the brakes a few weeks ago...working good so far.
    '73 K5
    Chevy good...Ford bad
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I usually use never-seize on my caliper bolts, both on the sliding portion and the part that goes in the backing plate.
    I figure it's the little things such as that make a huge difference in a good brake job vs. an okay brake job.
    Tim
  6. chevrules
    chevrules 1/2 ton status
    Aug 26, 2001
    127
    Canada
    It could be the pads.When I put new ones on I file down the edges so they are not square.It works for me.
    chevrules...always has and always will
