Squeaking that increases w/ RPMs???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Feb 20, 2001.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Hey guys, my truck is squeaking. It sounds just like a loose belt, but it isn't that. The squeaking increases w/ the RPMs when you are moving, when you put it in neutral and rev it, it doesn't squeak. I thought it was the brakes, pulled them off today, greased the back of the pads, that didn't fix it. It sounds like it is coming from the front axle. The wheel doesn't move any when you pull on it, so I think the bearings are ok. I'm starting to get mad at this thing, please help! Thanks!
    Dawson
    Raleigh, NC
    88 K5, 4" lift, 33" BFG muds
  2. 86blazerk5
    86blazerk5 1/2 ton status
    Aug 9, 2000
    387
    Hagarstown, Maryland
    Are you sure it is not your speedometer. That is what mine does.
    Ike
    Spreading The K5 Gospel!
  3. northgate
    northgate Registered Member
    Sep 29, 2000
    75
    Sisters, Oregon
    Check your universal joints, you may have a dry one. It might not feel loose, but it still may be bad.
  4. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Sounds familiar! Mine just did it this weekend. Found that the U-Joint at the rear yoke had one dry bearing cap (junk). Replaced it and stopped the squeak. Also you may want to repack the front bearings. Just cause its not loose, doesn't mean it couldn't use some grease. On that note, U may want to hit everything w/ a fitting!
    Why do people keep calling it a Bronco!!!!!
  5. Mud Bath
    Mud Bath Registered Member
    Aug 28, 2000
    84
    Wake Forest NC
    Dawson check your u-joints. The stock ones dont have grease fittings. Thats why they went bad. You might as well change both of them on the rear shaft. Especially now that you have the lift. I changed one of mine and with in a month the other one went bad. The neddle bearings were completly gone! The ymust have turned to dust. Anoyying squeak aint it ?
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I can't completely explain why it wouldn't do it in neutral, but I would guess that it is the A.I.R. pump. They squeak like a belt squeak when they start to go bad. Just pull the belt off (I think it is a separate belt on your truck), and see if the squeak goes away. You can also usually tell by turning the pump by hand. I had the problem recently on my '88 pickup, and it is very hard to isolate the noise from inside the cab. If you do need a new pump, pay close attention to whether it is the metric version or not. There are two versions of the pump that look exactly alike, but one has metric taps, and one doesn't. I have had the parts store sell me the wrong version.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  7. jerseymudder
    jerseymudder Registered Member
    Feb 13, 2001
    59
    south jersey
    UNIVERSALS ARE YOUR BEST BET. I'VE FOUND THAT ON MINE MORE THEN ONCE.
