squeaky clutch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chris Demartini, Jun 16, 2000.
  1. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>my clutch squeaks real bad, anyone got any ideas?</font color=blue>
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I was always able to fix it by spraying all the moving parts with a ton of WD40 or something similar. One of my friends told me once that lithium grease is better and longer lasting, but I just never tried it. There is also a grease zerk in part of the clutch assembly under the truck. Its on a horizontal tube like piece. I didn't find it until last week. It was all covered with mud and stuff so I didn't even know it was there.
    '73 K5
    Chevy good...Ford bad
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    When is it squeeking?
    When you push it in? Let it out? While driving?
    How old is it? ThrowOut bearring? Spring/linkage?
    Mine stoped when I put in a new CenterForceII Cluch kit w/throwOut berring.
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>it squeaks when pressing/depressing the pedal. I have the same clutch, new in october with new throwout bearing</font color=blue>
  5. Burt4x4
    6,854
    OK so are we talkin about a drivetrain squeek or a pedeal in cab squeek? If the squeek is out side I would bet the throwout is the cause, even new poor greasing/dry out????
    In side, I would lube all piviot points and return springs.WD40 is a temporary lube, it will evaporate eventually so use something else.
    Good luck
