squeal at ahigh rpm
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by badazzchick, Mar 6, 2001.
  1. badazzchick
    badazzchick Newbie
    Feb 11, 2001
    Washington State
    truck squeals(belt whine?) at about 3500, what is t his from? should i loosen the belt(S?)
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    does it sound like a bearing? You can check the belts for looseness. they are only supposed to flex about 1/4 of an inch at most. Pull off all the belts and check all the pulleys. spin all of them slowly and see if they are free and then try it spinning it fast and see if you notice a noise. a common thing is your water pump pulley and your alternator pulley
    [​IMG] Keep your feet dry [​IMG]
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  3. freeforever
    freeforever 1/2 ton status
    Feb 21, 2001
    305
    Missoula, MT
    Mine did the same thing....just look at the belts and lossen or tighten them and see what happens.
  4. Grim-Reaper
    7,385
    Atlanta
    Belts. Real booger to tighten the power steering belt. Lady Reapers truck did the same . Just not a good way to get leverage. If your A/C belt is off that makes the problem worse. Even if your A/C isn't working but it has a good clutch try to run the belt. It will help keep it from squeeling.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  5. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    If it's a sepertine set-up, check the tensioner and idler pulleys, things get REALLY interesting when the bearings on these let loose or seize on the freeway! (Cheap and easy to replace though)
    Why do people keep calling it a Bronco!!!!!
