Squeal at mid to full throttle?
Discussion in 'The Garage' started by k20, Mar 10, 2004.
  1. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Hey all, just for background I have a fanclutch I think is bad so you may say that is the prob, i just dont have cash to fix it right now. Whenever I give it mid to full throttle i get a squeal from teh front of the motor (sound like atleast) that wont stop until I let off the gas. It doesnt do it if its in park just when going down the road. Any ideas what it could be?
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    You have a loose belt somewhere.
    Check them all and make sure they are tight.
    If the belts are old, you should look at changing them. Old belts can become hard causing them to slip under load.
    /forums/images/graemlins/thumb.gif
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    theyre all tight and theyre all new. Hmn now that I think about it when i misplumbed powersteering system (dont ask) and fluid went everywhere maybe some fluid got on the belts. Ill try some belt dressin see if that helps
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I thought my Alt belt was tight and it squealed. I put a wrench (big) in the hole in top alt bracket and put more tension on belt, no more squeal. Just a thought. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    when i say tight it deflects down MAYBE 3/4 of an inch, should it be tighter than that?
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I always like 1/4 inch. Works in my case. Cost nothing to try it. Hope it helps. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    thanks, i looked at tension again, its about 3/4 of an inch if i press hard, ill tighten em up tomorow afternoon.
