squealing front driver side
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bad andy, May 21, 2003.
  1. bad andy
    bad andy 1/2 ton status
    Mar 5, 2003
    151
    Charlotte, N.C.
    hey guys thanks for takin time to read this. a couple days ago it started i noticed it drivin down the highway i only heard it cause the noise was echoing off the concrete wall, now i can hear 30+ mph. again it is on the front driver side, high pitched squealing, not constant all the time. i'm guessing something needs to be lubricated, what do you guys think it is? thanks again for your help
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I think that this is chit-chat, and you'd likely have much better luck if you put this in a tech forum... /forums/images/graemlins/thumb.gif </font>
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    well theres only really a few things it could be, Bearings, Brakes, or somethign is stuck in there like a piece of gravel, rubbing on your wheel or brakes somewhere.... just take it apart and look, May aswell replace the seal and repack/replace the bearings while your at it, If you need to replace bearings, you need to replace the races aswell.
  4. bad andy
    Mar 5, 2003
    151
    Charlotte, N.C.
    ok thanks for your input silver. i don't have the tools to do much of any work on my truck /forums/images/graemlins/tongue.gif, so i guess i'll have my dad take it to his dealer.
  5. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I have heard really really bad u-joints make a squeeking noise. Hey, we are close, Charlotte and Greensboro. /forums/images/graemlins/thumb.gif
    -Harrison
  6. win717
    win717 Registered Member
    Mar 8, 2003
    60
    PA
    Well it could just be a sticking Caliper,very common or it could be a brake hose that isn't letting the fluid go through right /forums/images/graemlins/grin.gif
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    front ujoints wont be turning unless hes locked in.
  8. ankarback
    ankarback 1/2 ton status
    Oct 8, 2002
    294
    Huddinge, Sweden
    Hi Andy!
    I have the same problem with my -76 Blazer but the squeeling sound is on the passanger side and only in 4wd.
    If you find out what it is, write a line here. I´m thinking of changing wheelbearing but if it´s something else I´m happy not to do that.
    /Johan
  9. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Or the brake pad could be worn out and is rubbing its wear indicator on the rotor.
    John
  10. bad andy
    Mar 5, 2003
    151
    Charlotte, N.C.
    cool, thanks for you input fellas. once i get it fixed i'll let ya'll know what the problem is and how it was fixed /forums/images/graemlins/thumb.gif
  11. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Johan, if the bearings haven't been repacked or replaced all together in a while, you should go ahead and do them regardless. A wheel bearing is one of the last things you want to fail on the highway. If you don't know how, just do a search since it's been covered many times...
  12. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    I know how to do it, and that´s why I don´t want to :-)
    /Johan
