Squeek at Full Turn
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Boss, Jun 15, 2000.
  1. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Just wondering if this is normal or not. When I turn my Blazer at full turn, left or right, it makes this squeeking noise, but when I let go of the steering wheel, the noise stops. It only happens when I am turned all the way and I keep it all the way, I don't have to be moving either. What could cause this? I don't think it is severe, that's why it took me forever to post it, but it was just a little embarrassing the other day when I was pulling out of my parking spot and a bunch of hot chics were walking by and SQUEEK SQUEEK.
    Boss
  2. Balou
    Balou 1/2 ton status
    Apr 15, 2000
    207
    back to Germany
    try fixing the P/S belt!
    Balou
    '79 K5,350,465,205
    [​IMG]"Size DOES matter!!!" said the girl last night [​IMG]
  3. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    My moms malibu does that, acctually it did it 9 years ago durring my drive test, the inspector thought it was funny, its just he p/s belt, if its not tight enough, is slips when you get to full lock and the pump gets loaded up, just tighten it, or put on a new belt, or try some belt dressing.
    RaisedK5
    "Friends don't let friends drive Fords"
  4. Boss
    2,550
    Maryland
    Cool, thanks for the info guys. I'll check that tonight.
    Boss
  5. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    You should never try and hold your steering at full lock either way, what is happening is that your gearbox and pump are fighting against the stops on your axles, causing a lot of stress in the pump. This is also what causes fanbelts to wear out abnormally quick.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That noise is your power steering pump screaming for mercy. You're telling it to try to bend your frame and it's saying "but I can't!!!!!". NEVER hold the steering wheel so that the steering mechanism is against the stops. Your hydraulic pump (the steering pump) is capable of putting out 1,200 PSI. When you're holding the steering against the stops, that pump is working way too hard for nothing. Back off on the wheel an inch or two and the noise will magically stop. [​IMG]
    http://ThunderTruck.ColoradoK5.com
  7. Laurie
    Laurie Registered Member
    Jun 3, 2000
    44
    Oregon
    Hey Balou:
    Just so you know. I had same noise problem and your suggestion was right on target. Tightened belt today and NO MORE NOISE. [​IMG]
    Thank you, thank you, thank you!
  8. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Could be the mouse in your pocket....hehehehehehehehehee
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  9. Laurie
    Jun 3, 2000
    44
    Oregon
    Tehehe [​IMG]
  10. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    that was the truck whistleing at the chicks!!!
    as mentioned before , NEVER hold at full lock. it only takes about 8-15 seconds to boil over the oil in the pump, soon after that the oil molecules break down and by then you would be better off having water in the system for lubrication.
    Knife.
  11. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    How many of you all have changed the oil in the p/s pump? How often? I was just thinking, the only time I ever changed the p/s fluid was when I replaced my motor, and that's only cos I bumped it and the cap wasn't on, so I refilled it. That makes it....... well, once in the last nine years!
    creepin' and crawlin'
    Jim
