Squeeking driveline???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nau81blazer, May 28, 2006.
  1. nau81blazer
    nau81blazer 1/2 ton status
    Mar 6, 2004
    329
    Cincinnati, OH
    Hey guys,
    I was driving the blazer on the highway today and it was having a really hard time going faster than 65mph. I thought maybe it was because my new 35" tires and my awesome 2.73 gears, but it's been able to do it before. When I got off of the highway, could hear a sqeeking/grinding sound. It mostly only does it when the throttle is applied. It doesn't happen when the brakes are applied (i just re-built the rear brakes about 1 1/2 years ago). It's hard to tell exactly where it's coming from because I have to let the truck idle along by itself:eek1: . It almost sounds like it's coming from the rear driveshaft? The u-joints are pretty fresh though. I'm hoping that it's not the bearing for the pinion. Is that something that fails very often? It's not a really abrasive or loud squeeking but I can hear it from the cab. Any ideas? Thanks guys!
    --Adam
  2. sweetk30
    Nov 1, 2004
    25,529
    527
    horseheads , ny 14845
    i would block the wheels and let the tranny stay in nutral. then get under the rig and check for free play in the drive shaft/ ujoints/pinion/tcase output. you never know. also look for the joint caps spinning in the yokes.
  3. nau81blazer
    Mar 6, 2004
    329
    Cincinnati, OH
    cool, i'll go check some of that stuff. Are you talking about blocking the front wheels and lifting the back up and letting it spin? I assume anyway. Thanks for the suggestion. Anyone else have some ideas? Thanks again guys.
    --Adam
  4. Wishbone
    Wishbone 1/2 ton status
    Mar 6, 2006
    239
    Oklahoma
    My rig does something kind of like that. At or above 65 mph it surges in and out of 4th gear. Like it doesn't have enough power to stay in 4th so on hills and against a strong wind it downshifts to keep up. What year, engine, and fi/carb are you running?
  5. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    when you're on level ground and in neutral, is there any play in the diff yoke?
    and golly you need some gears, do you get any axle wrap?
  6. nau81blazer
    Mar 6, 2004
    329
    Cincinnati, OH
    I've got a tired 350 with a 670 truck avenger, and yes I definately need gears. Too bad I don't have the $$$$. I don't really get any axle wrap at all. I'm not sure about the play thing, i'll have to check. Thanks for the responses. Anyone else???
    --Adam
  7. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    That squeaking under load is more than likely a u joint beginning to fail. I have had the same issue a couple of times. I wasn't keeping up on the maintenence. Pull the u joint at the axle and check the needle bearings. At least one cap will most likely be dry.
    John
  8. sweetk30
    Nov 1, 2004
    25,529
    527
    yep i dont buy the cheep joints at all any more. and even stay away from greasable. buy premo and sealed non drilled cross. brute force and spicer is great in my book. also car quest gold is brute force. and last napa no longer sells name brand in there boxes. its all jap junk.
  9. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    X's 2
