Squeeking in the dash/steering column
Discussion in 'The Garage' started by MilpitasK5, Dec 22, 2002.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    There's a squeeking noise coming from my steering column or under the dash (not sure which). It sounds like it's moving with the wheels /forums/images/graemlins/shocked.gif.
    If I go faster it squeeks more and if I stop the truck, the noise stops too. I've never heard it before. Anyone know what that could be?
    It's an 86 K5 with a 350 and 10bolts. When I rolled down the window to see if it was outside, it wasn't. Oh yeah, tilt steering column too.
    It seems kinda weird to me. /forums/images/graemlins/confused.gif
    Thanks,
    Chris
  2. nevercomplete
    nevercomplete 1/2 ton status
    Dec 25, 2001
    309
    Beaufort, South Carolina
    sounds like your speedometer cable. mine did the same thing,they get dry and you have to oil them. i did that and the noise completely stopped. hope this helps.
  3. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    /forums/images/graemlins/thumb.gif That makes sense. A few months ago, I found my speedo cable exposed b/c it sat on my exhaust pipe. I haven't gotten around to taping it up.
    Where should I oil it from?
    Thanks /forums/images/graemlins/ears.gif /forums/images/graemlins/thumb.gif
  4. nevercomplete
    Dec 25, 2001
    309
    youll have to take off the gauge cluster and disconnect the speedometer cable and oil it from there.
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> If your exhaust burned through the casing you might as well replace the cable now, because it won't last long that way... /forums/images/graemlins/wink.gif</font color>
  6. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    I guess you're right. Sounds like a fun one to do! /forums/images/graemlins/crazy.gif
    Thanks nevercomplete! /forums/images/graemlins/thumb.gif
  7. nevercomplete
    Dec 25, 2001
    309
    no problem, good luck
  8. blazerman78
    blazerman78 Registered Member
    Oct 16, 2002
    77
    Connecticut
    Did you check to see if there are any mice or other small woodland creatures in there? /forums/images/graemlins/rotfl.gif Yeah, I think you should check the speedometer cable, and maybe your power steering or alternator belts and/or bearings (not likely) if you really cant find anything else wrong.
