squeeky brakes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Orange, Aug 27, 2000.
  1. Orange
    Orange Registered Member
    Apr 2, 2000
    32
    Prescott Valley, Arizona
    I just took my Jimmy out in some mud today. I was out there playing around for about and hour and then left. ON the way home I noticed my brakes were squeeky when I applied them. Is this bad for them or is there a way to make them so they won't do it anymore? Thanks for the help.
    Orange 84' Jimmy
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Its probably a good idea to wash out your brakes (depending on the type of mud)
    I had wheeled in some river mud and the silt in my brakes wiped everything out (rear drums)shoes, wheel cylinders, E-brake mechanism, adjusters and axle seals. I wish that I would have washed mine out.[​IMG]
    The front brakes are discs and should be OK
  3. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Also the possiblity of the rotors have gotten "glazed" which will make the squeek like no tomorrow...as Rk5 indicated try cleaning every thing out real well and if that dosen't help most likely they're glazed.[​IMG]
    <font color=blue>White Knight</font color=blue>[​IMG]
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    That happened to me after doing donuts in a wet baseball field. I think its just moisture getting on the brake pads.
    90K5
  5. White Knight
    889
    Ft Worth,Texas
    Why would one want to do donuts on a Baseball Field, unless I miss my guess you're supposed to play baseball there, I hope that when you where done you went back and filled all the holes and resodded the field...jeez
    White Knight
