Squeeky column
Discussion in 'The Garage' started by MTBLAZER89, Jan 18, 2005.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Just noticed the other day when I turn I have a squeek squeek squeek coming from my column. The column still fells tight with no movement up down left or right. Is there a way to get in there and lube them, or just deal with it?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Aftermarket wheel ?? When I put my grant on and tightened it down the black metal piece that hides the backside rubs the plastic piece over the lockplate . Makes a squeak sometimes :k5: :k5:
  3. dyeager535
    26,982
    191
    Mine squeaks sometimes too.
    I figure if its squeaking, its good. When it loosens up, then it will stop squeaking and needs to be tightened. :)
    Noticed it only does it once in awhile though, not constant enough to be annoying.
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    It sounds like a bearing inside that needs some WD-40, but I'll check that plastic piece.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    wd40 jsut dries up, use sewing machine oil, etc that will actually stay put
