SRW or DRW 60?
Discussion in 'The Garage' started by mtnman210, Sep 10, 2005.
  1. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    ok I'm looking for a front dana60 to go with my 14ff. But I've seen there are both SRW and DRW ones. I always thought srw-single rear wheel and drw was dually rear wheel. How can you have a dually front? or does it just mean it came from a dually? And which one should I go with for under a 77 k5?
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    In a nutshell, a DRW front 60 just has a hub that extends out a little bit more than a SRW 60 would have. It's because of the rims that come on duallys. Nothing to do with dual front tires.. just denotes that the rear was dual... and therefore has different hubs up front. DRW is good if you want to run H1 hummer wheels. SRW for running something with a more common off-set.
  3. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    thanks thats just what I needed to know. I just plan on runnning some run of the mill steelies so I'm not worried about the extra hub width.
  4. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    If you run standard offset wheels on a DRW frontend, you are not gonna like it. They will stick out A TON on the front.
  5. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Cool beans... then you would be wanting to find a SRW D60. :thumb: If you only find a DRW that's no biggy either.. as more than likely you can find someone here willing to trade hubs. However if you can't find someone to trade with you, then it's a little pricey to get the hubs replaced. :(
  6. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    cool...thats good to know
  7. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    it's not like it used to be now you can get a pair for $300 or less.
    highhonda or on pirate4x4.com has great deals on hubs.
  8. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    highhonda= 410.00 for a set delivered.... they are expensive
  9. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    I was actually looking at highonda's axles. Has anybody dealt with him. are his prices reasonable or should I keep looking in the junkyards and different boards?
  10. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    when i got my dana 60 it came with the dually hubs machined down to a srw mounting surface. I wouldn't recomend this if your going to drive the truck on the street though..
  11. sebban
    sebban Registered Member
    Jan 18, 2005
    63
    sweden
    Do you have any pics or additional info about this, since I´ve just found a dana60 dually front axle. I want to know how I can make it narrower like a standard axle..
