SS brake lines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChevBlazin, May 6, 2002.
  1. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    Has anyone used stainless steel brake lines from companies like classic tube, and others? I want to replace the lines allong the frame and above the rear axle. I think these are pre-formed from some companies. I will be replacing my rubber ones with braided lines soon and didn't think it made much sence to hook the nice braided lines up to old rusty ones on the frame. What kind of lines have the rest of you used? thanks!
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
  3. Parf
    Parf Registered Member
    Nov 16, 2001
    81
    Golden, Colorado
    I don't think thats what he was talking about. Has any one bought the entire hard-line system replacements from someone like classic tube or inline tube or one of those companies?
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Right... my bad! /forums/images/icons/blush.gif Why not bend them up yourself? You can then have the props all to yourself when its all over! That, and you will have saved some pretty good $$$ I would guess! /forums/images/icons/wink.gif
    -Dan
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Have you tried "Fine Lines" 1-800-ss-tubes. They have a kit for the K-10 that worked on my K5.
  6. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    How much was the kit from Fine Lines?
  7. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    $90, for 4 lines, there pricey, they are mint though, including all factory bends, fittings, and the spring material to protect against fiction.
  8. ChevBlazin
    Feb 4, 2002
    332
    thanks for the replys, I may just bend them my self and save some coin. I already have one of those small benders anyway. Do I still have to special order SS or do auto supply stores have it. What is the point of the lines under the brake booster "swirling" around a few times? So it can flex?
  9. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    A small bender on stainless.....I don`t think so...you'll need something bigger for stainless.....it doesn`t bend easy.....and you`ll need flare your lines....no, a standard Flaring tool won`t work very well, but if your like me you`ll try it! As far as tubing goes, I went to a brake line / truck parts shop in town!
