SS Brake lines
Discussion in 'The Garage' started by Hossbaby50, Nov 23, 2002.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Will the SS brakes for an 85 GMC with a 10bolt (stock calipers) work on a 72 Blazer with stock calipers? I don't think they will, I recall that D44's & 10 bolts have different banjo bolts. Am I correct or mistaken?
    Superlift part #3095-6
    Thank you
    Harley
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    No.
    The banjo bolts for the front calipers are different then the 10B and the rear line asside from being the wrong size for the axle hard lines will be only about 2" longer then your factory line.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I recall that D44's &amp; 10 bolts have different banjo bolts.
    That's right, the d44 uses the large banjo and the 10b and d60 use the small one.
    -- Mike
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    THanks guys, that is what I thought, but wasn't 100% on it.
    Harley
