SS line on 14bff disc conversion...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Jul 1, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Okay..so I decided to go disc on my 14bff...I have the extended brake line from the chassis to the axle...now where can I pick up a male-to-male FLEXIBLE stainless steel braided line to go from the caliper to the extended line i already have? Will I have to have some line made or what? Doesn't a company like Russell have pre-fabbed lines in different lengths? Thanks for the help guys...
    Chris
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I bought mine at Speedway Motors. They sell different sized pieces and any fittings to make them work.
    www.speedwaymotors.com
  3. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I may be a little confused by your question, but are looking for the line to go along the axle itself connecting the main line to the two calipers? If so, I just ussed plain old brake line that I hand bent. Got it at O'reily's and slapped it on. Hard to tell it's not factory. The lines from the calipers down to the new hard line are TSM lines, but any flexible brake lines will work. I went through TSM for convenience. The lines at the calipers won't move much, if at all once they are on.
  4. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    Are you still in Ft.Collins?? If so there is a place called Tubes'n'Hoses, down Lincoln in the Maztech building. Just bring them a sample just to get it right, and in about 2 hours you got your hose. I costed me around $80, because the banjo bolt fittings where pretty pricey. You should check them out.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    TSM's lines are only $50.00
