SS454 rear end! What was it?
Discussion in 'The Garage' started by Corey 78K5, May 16, 2005.
  1. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Is it true that the SS454 rear end was a 5 lug SF 14 bolt? Or was it just a plain jane 10 bolt?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    5 lug 14 bolt semi floater
  3. Corey 78K5
    13,055
    Humboldt County, CA
    Ok so Your right after a further search. Next question! Can a six or eight lug SF 14 bolts have their axels swaped out for five lug units?
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Your guess is as good as mine on that. If you have one or have access to one, I'd sell it to some lowered truck guy. Someone with a hot 350 or something out there has to want one.
  5. Corey 78K5
    13,055
    Humboldt County, CA
    I would like to have one or build one for My 96 C1500 that I am really thinking or doing a pre-runner lift on. Would be a bolt in and would hold up just fine to 31-32's with a locking diff. Time for more reserch!
  6. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    I just saw one the other day and Im almost postive it was 6lug
  7. Corey 78K5
    13,055
    Humboldt County, CA
    They were 5 lug. The new SS trucks (with the 6.0) are 6 lug.
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I suspect you can swap the 5-lug 14SF axles into the C2500 6-lug housing. You might be screwed for brakes though. 8-lug housing is a different width again AFAIK.
    The better way to go is 6-lug. The 5 and 6-lug 2wd rotors can be swapped with no other changes.
  9. Corey 78K5
    13,055
    Humboldt County, CA
    Wasn't the 6 lug rotors only offerd on the K1500/K2500 models? All I have ever seen 8 lug rotors on were C2500 and C3500 models as far as 2 wheel drive goes. BTW I am refering to 88-98 years.
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
    I'm talking about 88-98 years also. Light-duty C2500 is 6-lug. The 5 and 6-lug rotors are directly interchangable.
  11. Corey 78K5
    13,055
    Humboldt County, CA
    Well that would rule seeing as I already have a 6 lug SF 14 bolt :grin:
