!st generation steering brace
Discussion in 'OffRoad Design' started by 1HIHUM, Dec 12, 2000.
  1. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    Is there such a creature? I'm trying to eliminate any flex or chance that I'll crack my frame. Thanks in advance!
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Re: 1st generation steering brace
    Ya is there??
    On my 72 I have the plate on the inside of the frame and then a piece of square stock 2x2 I think running accross the front from frame rail to frame rail.
    1HIHUM what do you have up front on yours??
    SW will be placing an order soon (Feb.) for a complete set of axels for my Dana44 so get ready[​IMG]
    http://www.burt4x4.coloradok5.com
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We don't have a brace for the early K5, mostly due to lack of demand. I don't know if it's from fewer trucks, or if they're more durable, but we don't have many calls for them. We have tried the later model stuff and it doesn't work on the early chassis. Maybe we need to come out with a brace for the 67-72?
    SW-ORD
  4. 1HIHUM
    Jun 28, 2000
    366
    Fremont, CA
    First, let me say thank you for taking the time to respond! Second, I'm not sure that I need it. I have a gooood amount of wander, especially on rough streets, but since I have an eight inch lift with the "recommened corrections", and 40" tires,I am not sure that frame flex is the culprit. I was curious though, since I haven't seen any braces for the first generation blazers.
  5. bushwacker
    bushwacker Registered Member
    Sep 8, 2000
    58
    Orange County, Calif.
    Stephen, I sure could use a steering brace on my 72. Frame is cracked at box. Let us know when one is avail.
  6. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Looks like there are alot of 1st gen. K5's out here that would like a brace. So how about it Stephen? When is it going to be out? LOL. My frame is still ok, but after I put my 35" tires on I would love to have a brace on the frame for preventive maint.
    [​IMG] I have to agree with the Puddy Cat. [​IMG]
  7. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Couldn't you guys just find a local welder and have them cut a plate and weld it on there over lapping the cracked area, then drill, or have the holes pre-drilled to meet the steering box.
    I miss my Ex, but my aim is getting better!
    http://mccordhouse.freeservers.com
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The nice thing about a bolt on brace is that it bolts on. And being inside the frame rail, it triangulates the area, rather than just making it thicker. This helps take the flex out of the crossmemer and frame right there so it's stiffer. I'm pretty sure the weld in repair kit works on the early trucks also, but it's still not the same as the bolt in brace.
    I'm not going to make any guarantees as to time frame for starting a kit, that usually gets us in trouble! We'll start taking a closer look at it though.
    SW-ORD
