Stabilizer or hydro?
Discussion in 'The Garage' started by ssped, Mar 29, 2007.
  1. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    It only happens verry rarely but I occasionally get Death wobble when hitting a pot hole. I have been searching here and came across someones imput stating with Hydro that the DW would not happen. I am running a 10b with Xover. Is that correct?
  2. stevos67k20
    stevos67k20 1/2 ton status
    Sep 29, 2005
    140
    Somis
    do you have a stock caster angle? lift springs may angle your pinion too far forward and mess up your caster. i just put a steering stabilizer in my dana 60, cuz ive never had one and it, and it made a real difference at slower speeds, not so much on the freeway. i'm sure it would definately help you out though. and it WAS noticable.
    if a stabilizer doenst work, sell it on ebay. its a way cheaper trial run that getting a hydro assist right off the bat.....unless you really really need it.
  3. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    i just gave domonic a brand new steering stabilizer, he just got hydro so he isnt using it, might wanna hit him up for it, it got rid of my death wobble while i had it, they help mask slop in your steering
  4. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I had DW real bad on my 60. Rebuilt the kingpins, same, added stabilizer, same.
    Just did hydro last weekend and it's completely gone. Cost me 89.00 for the ram from surplus supply and 100.00 for custom hoses. Total 190.00
    Before I got to where I wouldn't drive it at all, it was just too annoying.
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You need to figure out what is causing it,
  6. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You need to figure out what is causing it, not
  7. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You need to figure out what is causing it, not just
  8. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You need to figure out what is causing it, not just cover
  9. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You need to figure out what is causing it, not just cover it
  10. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You need to figure out what is causing it, not just cover it up.
  11. oneofthefewbmx
    oneofthefewbmx 1/2 ton status
    Oct 6, 2004
    579
    Copperas Cove, TX
    im curious why your hoses cost you so much, did you need special custom hoses with different fittings or wat? a 48in hose w/ 1/4 NPTM fittings on both sides is like 8 bucks from surplus center .com......
    http://www.surpluscenter.com/item.asp?UID=2005122900455966&item=916-1448&catname=hydraulic
  12. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Hydro assist is just another band-aid until you fix the problem.
    Jack up the front end and watch the steering ends for play with a freind turning the wheel.
    Jesse
  13. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I have hydro assist and I had death wobble so bad I could not drive my truck at all.I put in new king pin springs,plastic bushings,and an 1/8" shim on top of the spring and that fixed it.I had tried the shim by its self but it did nothing for it.
    Upper king pin parts are cheap.I would look at that if you have not already.
  14. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    it is a 10b with new Ball joints, bearings, cross over steering with new TRE's... there is no play at all in the steering. it has only happened twice in3 months at like 30mph. it is still scary when it happend but totally negotiable. I am leading towards adding the hydro to it if it will dampen it a smidge it should be gone.
  15. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Hydro will almost certainly make it go away, but it's still a band-aid solution. It's like wrapping your entire arm in a gause for a paper cut, (read: it does a good job at masking it) but it still didn't fix the root problem.
  16. blasphemous
    blasphemous 1/2 ton status
    Jan 11, 2007
    457
    Louisville, KY
    /fixed
    (I think DW is more comparable to a broken arm. A paper cut would be more like a torn TRE boot) :p
  17. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Opps,missed the 10 bolt part :D
    I had a Dana 44 with new everything and I got wobble pretty bad sometimes.I put a single stabilizer on it and it got rid of it.
    As long as you know everything is all good and nothing is broken or worn out,a stabilizer is fine.You will just have to put up with the its just a bandaid crap :D
  18. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    I think I will install Hydro assist on her. It is under 200 bucks and that will be an upgrade to the system rather than just mickey mousing a sabilizer onto it. I would have to do the same work to put a stabilizer on as the Hydraulic ram onto the Xover. Might as well make it better Right!
  19. blasphemous
    Jan 11, 2007
    457
    Louisville, KY
    How can you do hydro-assist for under $200? I'm probably going to HA also, but all I've seen is like $500 kits. I already have high-steer and X-over steering on a D60.
  20. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    When you guys refer to "hydro assist" are you referring to just normal power steering? Because my Jimmy came with stock power steering. Or is there another fancier type of hydro assist out there, besides cross over?
