Stabilizer shock setup?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Rhody, Nov 30, 2001.
  1. Rhody
    Rhody Registered Member
    Oct 8, 2001
    22
    Wallingford, WA
    I just put a Rock Rod on the front end and now I am looking at putting a Stablizer shock up front as well. I have the bracket with the U-bolts to install to the Tie rod, Is there a kit I can get that just has the shock and maybe a bolt with poly bushings to mount up to the axle? or does anyone have any advise on what shock to get and how to mount it to the axle? Thanks in advance.
    Little Rhody
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Most of the offroad shock manufacturse should have a listing for a replacement for trucks that came w/ a steering stablizer from the factory. Than you would just have to use a regular bolt (they come w/ the bushings).
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
