Stacking pinion angle correction shims
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88jimmy4x4, Nov 21, 2003.
  1. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    I need to add a 6 degree shim to my rear diff to correct the pinion angle. The leaf packs allready have a 3 degree shim. Are there any problems/dangers with stacking shims?
    I plan on doing this in a couple hours so please respond.
  2. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Nope. Don't do it, it'll spit out those shims quick
  3. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    Even if the center pin goes thru it?
  4. Bullet
    Mar 14, 2001
    1,222
    Abilene, Texas
    Try and PM Laketex, he had stacked shims on his axles and I think one spat out, not sure If it was bolted though
  5. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Just buy a 9* shim and bolt it to the pack. Do not stack them or put them in loose.
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    Don't yell at me, but I have actually done this successfully (so far?). The key is to put the spring pack center pin all the way through everything. You also need a flat spot on the bottom shim that is parallel to the leafs so that the bolt is pulling straight. As long as the U-bolts are tight (you should check them anyway, but that's another topic), the only way to lose one is to shear the center bolt. Since the same bolts are used for huge thick spring packs on 1-tons and such, this shouldn't be a problem.
    I agree that it is better to use a single degree shim, but it still should have the flat spot to avoid bending or stressing the bolt.
    Best yet is to move the spring perches or turn the tubes. However, that is pretty final, so I like to try out an angle with shims for a while to make sure its' right.
  7. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    Okay, they are all installed, stacked them and it worked fine so far. The pinion angle is now perfect. I dont see how it would be a problem stacking as long as the bolt goes thru both and also as stated, I got the flat shims.
    Side topic......Does anyone make custom rear blocks like a 2" with 13 degrees or whatever you specify?
    I really dont like the stacked shims and If I could getr a custom block made that would be great.
  8. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    PM TonyP....
    He made me a 5* shim with 5/8 height to correct a spring perch problem I had. Excellent workmanship and very fast turn around. The tall shim he made for me had a threaded hole in the bottom(flat) side, into which he had inserted a locating pin. He drilled and tapped the remainder of the locating pin hole to match the angle of the top of the shim, and provided a allen head bolt so I could bolt it to my spring pack.
    The install was really good (front D60), and I have had no problems thus far.
    Byron
  9. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    Thank Byron /forums/images/graemlins/thumb.gif
    I will definately PM him.
  10. SCJimmy
    Mar 7, 2003
    406
    /forums/images/graemlins/k5.gif /forums/images/graemlins/grin.gif
  11. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Az-Kickin' sell them, too. Link's at the top of every page on the garage.
  12. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    I went to their website but they only go to 8 degrees /forums/images/graemlins/thinking.gif
  13. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    John, We also do custom machining if you want to give me a call with you requirements.
