Stainless Steel braided lines, simple question
Discussion in 'The Garage' started by mrk5, May 23, 2006.
  1. mrk5
    Apr 20, 2004
    12,351
    1,051
    Northern Colorado
    Can you use regular worm gear hose clamps with stainless steel braided hose?
    Anybody have good bad stories to share about doing this?
    I want to redo my tranny cooler lines, but the B&M cooler has barbed fittings.
    Just thought of another question, will any of the -AN size hose fit the 3/8" barb well enough?
  2. slyguy_22
    slyguy_22 1/2 ton status GMOTM Winner
    Dec 13, 2004
    789
    Lancaster, PA
    u should be able to clamp it. not much preasure there
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    when i did mine i saw some of the bradied line being used with clamps
    but i ran mine with the flare to -6an adatpers, and used the stuff that came with the cooler.
  4. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Scott,
    hose clamps work. You can even get the ones with the fake 'anodized aluminum hose end' look :D , although they actually don't clamp very well, better to use a bigger hose clamp size.
    Some of the stacked plate coolers out there have 1/2" female NPT ports; you can get a -AN to NPT adapter...
    IIRC #6 hose should fit. I've done my tranny cooler plumbing in #6 hose and -AN fittings, including bulkheads thru the rad support.
  5. mrk5
    Apr 20, 2004
    12,351
    1,051
    Northern Colorado
    I wish now I'd had the foresight to get the cooler with 1/2" NPT fittings. I did the engine cooler that way so it can done with stainless steel braided lines. I'll use the hose clamps for now.
    Micheal, I like the use of bulkhead connectors through the radiator support. Bet that looks nice and clean. Unlike all the rubber hoses I have poking through miscellanous holes and lying all over.
