Stainless Steel Brake Line and 1 ton question
Discussion in 'The Garage' started by unick, Feb 17, 2004.
  1. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Im getting ready to put 1 ton gear and a 6" lift on my truck. What kind of ss brake lines should I get? Im thinking +10" lines will be good because I want a little play in the lines because my suspension is really flexy.
    Nick
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    IMHO 10" isn't quite enough, especially in the rear. I used ProComp front and rear, the 10" fronts can be streached to the max, and the rear is to short and would not allow the rear to fully drop.
  3. unick
    Aug 16, 2003
    4,286
    ok then what do you suggestI get? +12"?? Also what brand?
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    I'm not sure how much longer than stock mine are, but they're 32" each, front and rear. The fronts are probably a wee bit overkill, the rear is so long it's ridiculous. The axle could come out on the freeway and it would still probably take a few seconds for the line to break. OK, so it's not quite that long, but you get the idea...
  5. unick
    Aug 16, 2003
    4,286
    Where did you get them? What brand and how much? PN??
    lmk
    Nick
  6. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    I got them from Rock Equipment, I think I paid about $100 for all three. They're basically just AN lines with adaptors for each end so you can attach them to the brake system. I figured thast this way I'll always be able to reuse the lines on different brakes, axles, whatever, just get a new ends for them.
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    For a lot of travel you might want to look into a center drop line like on the dodges. It causes no limitations where even the longest lines fail, and you don't have to worry about them rubbing tires and steering.
  8. unick
    Aug 16, 2003
    4,286
    how hard would it be to do this??
  9. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    I am lifting my truck and need lines as well. I am going to get my lines from www.truckperformance.com . They sell Russel brake lines which are pretty good and they come in the following type:
    90° TO STRAIGHT
    BANJO TO STRAIGHT
    STRAIGHT TO STRAIGHT
    and you can get any of the following lengths:
    9 INCH LENGTH
    12 INCH LENGTH
    13 INCH LENGTH
    14 INCH LENGTH
    15 INCH LENGTH
    16 INCH LENGTH
    18 INCH LENGTH
    20 INCH LENGTH
    21 INCH LENGTH
    22 INCH LENGTH
    24 INCH LENGTH
    26 INCH LENGTH
    27 INCH LENGTH
    28 INCH LENGTH
    30 INCH LENGTH
    32 INCH LENGTH
    33 INCH LENGTH
    34 INCH LENGTH
    36 INCH LENGTH
    38 INCH LENGTH
    39 INCH LENGTH
    40 INCH LENGTH
    42 INCH LENGTH
    50 INCH LENGTH
    53 INCH LENGTH
    This gives you plenty of options.
