STaK T case in 84 CUCV
Discussion in 'The Garage' started by silveradoreb, Feb 9, 2007.
  1. silveradoreb
    silveradoreb 1/2 ton status
    Mar 11, 2005
    150
    Boone,NC
    Ive got an 84 M1008, TH400 and 208 all stock. What is needed for a Stak 2 speed to go in. Crossmember mods? Also anyone know the input splines? And will drive shaft with my slip yoke still work? Thanks
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Uh 400 is 32 spline, Crossmember needs to be changed most likely custom, Your driveshafts will not work you will need a 2 piece shaft front and rear as both outputs are fixed yoke. And if you are going with a Stak why not a 3 speed price dif is not that much.
    Ira
  3. silveradoreb
    Mar 11, 2005
    150
    Boone,NC
    I beilive the 3 speed is about 700 more and 2 speed is plenty going from the 208. So nothing will "bolt in" like lomax 205? I was afraid of the driveshafts, but custom mount isnt a problem I just really dont like 208, it is always grinding lately and wont engage in 4hi or low, or stay in gear unless I hold it plus 2 speed is nice.
  4. sandawgk5
    Oct 28, 2003
    6,881
    The Stak to my knowledge has a round pattern. You might need an adapter to mount it to the 400. 32 spline is an option for the stak. The problem with your 208 is more than likely a linkage adjustment problem or maybe a bent shift fork. Shift forks are about $27 dollars. And also your 208 is a 2 speed case Hi and low so a 2 speed stak is the same stronger and deeper gears but still 2 speeds.
    Ira
  5. silveradoreb
    Mar 11, 2005
    150
    Boone,NC
    The twin sticks are nice to have though IMO.
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    The Stak is the way to go. Since you are running a 208 you can re-use your adapter and all you will have to do is egg out one of the holes a little bit, no biggie.
  7. silveradoreb
    Mar 11, 2005
    150
    Boone,NC
    What about a Lomax 205, Would this be any easier aside from new shafts?
  8. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    You will need to switch the adapter to go to a 205. You will need a round pattern 205 with the long 32 spline input to bolt to a th400 that had a 208 behind it. I think if you have to by the 205, Lomax kit, 205 rebuild kit, shifter, and adapter it will most likely cost about the same or more then the Stak.
