Stalling at lights????????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CTBlaz45, Mar 19, 2004.
  1. CTBlaz45
    CTBlaz45 Registered Member
    May 16, 2003
    50
    Killingworth CT
    I think that I have checked everything. MY 89 K5 with TBI is stalling alot but only after it has been driven for awhile I have replaced O2 sensor plugs cap rotor wires vaccum lines used 2 different computer chips etc. It is ideling around 500 rpm is that to low? any sugestions help please. /forums/images/graemlins/k5.gif /forums/images/graemlins/dunno.gif
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    500 is too low. What tranny? /forums/images/graemlins/ears.gif
  3. CTBlaz45
    May 16, 2003
    50
    Killingworth CT
    700R4 I found an adjustment screw to open the buterfly a little more thus advancing the Idle I hope it was a good thing to touch. What should it be at? At start? And in gear at a light. /forums/images/graemlins/whistling.gif
  4. CTBlaz45
    May 16, 2003
    50
    Killingworth CT
    I adjusted the screw which open the butterfly more, thus kicking up the idle. What should it Idle at on start and in gear when stoped? Oh and 700R4
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Check your IAC motor. This is what controls engine idle speed. You are not supposed to adjust the screw for the butterflys. Don't ask me why I have no idea but everyone I have ever talked to said do not adjust it.
  6. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    bacause in EFI, hat is not an idle speed screw, it is a throttle stop/minimum air screw
    the ECM controls idle via the IAC
  7. Grim-Reaper
    7,385
    Atlanta
    EGR is probably your problem. It's probabluy open at idle and it's not supose to be.
  8. CTBlaz45
    May 16, 2003
    50
    Killingworth CT
    Sorry to go back to this but I switched tbi unit to the Holley one. It is still stalling so where is the egr and how do I unstick it.
  9. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    the egr is on the intake manifold. There are variations on the shape etc of them, but it should be round, the base of it bolt to the manifold (bases can be diff shapes, top is round) and the top should be between 2 and 5" off the manifold and it will have a vac line going to it. You can see if it is stuck by pushing up on the rubber diaphragm inside the top (some have opening big enough other designs dont) if it is sticking (youll be able to feel it) replace it. I believe they are between 30 and 50 bucks. Also may try checking your IAC.
  10. CTBlaz45
    May 16, 2003
    50
    Killingworth CT
    I don't think it is the IAC cause I swithced tbi unit and I beleave that is on the actual throtle body.
  11. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    yeh its on the tbi, but w/ the holley you may have had to switch it over from your old one, unless the holley came w/ new sensors.
  12. CTBlaz45
    May 16, 2003
    50
    Killingworth CT
    The Holley unt doeas have its own everything just have to plug it in. My EGR moves when I push it with my finger. The vac line off of it goes to some sorty of relay unit that unit also looks to have a fitting for another vac line but tere is none there and the Chiltons manual sucks for tracing that stuff. Any help.
  13. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    yeh the egr vac line goes to the map sensor. I believe my SB one had 2 vac ports on it and both were hooked up, ill have to try to find that thing, or a pic of it and see where it went.
  14. CTBlaz45
    May 16, 2003
    50
    Killingworth CT
    MINe has 3 vac ports one form the egr, one from the TBI (in front) and a second in the rear with nothing.
