stalling engine?
Discussion in 'The Garage' started by MUD JUNKIE, Jan 31, 2003.
  1. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    when I give my truck quick amounts of the go pedel it stalls,now I'm not flooring it but giving it quick throttle response when in a gear(D,R,1st,2nd) I just put a edlebrock 650cfm carb on also.its a 350 v8
    /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
  2. bigbluek20
    bigbluek20 1/2 ton status
    Dec 18, 2001
    119
    Loveland, Colorado
    Could your vacuum advance be misconnected or not connected since you put in the new carb?
    Beyond that, I would explore fuel starvation (accelerator pumps working?).
  3. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    I just went through this also /forums/images/graemlins/angryfire.gif. Put on a new edelbrock and the engine would stall /forums/images/graemlins/confused.gif. Worked for months to find the answer... finally it appears to be: the accelerator pump. If you havent already, move the accelerator pump arm (on the RH side as you face it) up to the top hole. Then, re-time your engine. Mine needed to be advanced a little more than before I changed carbs, but not too much. That solved my stalling problem.
    -Ryan /forums/images/graemlins/k5.gif
