Stalling out when hot
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cabledawg, Feb 18, 2007.
  1. cabledawg
    cabledawg Secret Squirrel Premium Member
    Sep 12, 2006
    2,647
    Highway to Hell
    88 4x4 Burb 1/2 ton. 350/700/208. Runs fine when cold, but keeps stalling out when the engine is hot. Idles ok but the second I touch the go pedal it stalls. Dumping too much gas into the TBI. I can sit and watch it pool up when the engine quits. When I start it back up, lots of black smoke and reeks of gas. I've already checked the EGR, PCV and the entire TBI unit. I took the belt off the smog pump (AIR system) and at least now it will start when flooded. Any help will be much appreciated.
  2. Jrgunn5150
    Jrgunn5150 1/2 ton status
    Nov 26, 2005
    232
    Cleveland, Oh
    Did you check your IAC?
  3. cabledawg
    Sep 12, 2006
    2,647
    Highway to Hell
    Not sure what that is but the girl who owns this asked around and found out it might be the temp sensor on the intake manifold. Same thing? None the less, I'll try swapping that out and see if it works.
  4. Jrgunn5150
    Nov 26, 2005
    232
    Cleveland, Oh
    Ide Air Control, it's like your choke.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you can watch the gas pool up on the throttle plates when the engine if off you probabally have a leaking injector. They should not drip at all when the engine is not running. Have you checked for trouble codes? That should be the first thing you do before randomly replacing parts.
  6. cabledawg
    Sep 12, 2006
    2,647
    Highway to Hell
    No it was pooling up right before the engine quick, but it was the temp sensor so it is fixed and runnin like a champ.
