stalling when braking??
Discussion in '1983-2005 S-Series models' started by bryguy00b, Nov 10, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok..this truck runs pretty good for a 100 buck truck..but i noticed when braking it will want to stall..not always but most of the time..or when i come to a stop and the rpm's go down, and ill have to press the clutch in and rev it a little and it will be ok..neighbor said it could be a vacume leak but im not sure wear to look..
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If it is just under breaking you might have a vacuum leak in the brake booster. Try and block it off and see if it still happens.
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    thanx ill give it a shot! /forums/images/graemlins/grin.gif
